Main :: Flextone I / II / III / Duoverb / HD147
Can I use a Flextone II HD with a tube power amp
by ratpackid on 2011-02-19 16:43:06.6150
I wanted to know if I could use my Flextone II HD as basically a preamp? I want to run it with a Marshall 9200 power amp.
Re: Can I use a Flextone II HD with a tube power amp
by Nickbr on 2012-03-01 12:16:50.3170
yes you can. You can use the xlr outputs intop the 9200. But you will not be able to crank up the volume very much.
I did not try to use the normal outputs but it should work also.
Nick
