Please help...
by kuk3r on 2011-03-04 08:49:41.9150
Hello.
I´d like to ask which foot controller can you recommend me for switch presets in gearbox with Line6 UX8.\\
Thx.
RE: Please help...
by ricksox on 2011-03-08 12:48:11.4070
Hello,
You cannot switch presets in Gearbox with any pedal.
You need to upgrade to POD Farm 2 and use the Set List feature to change presets. You can use something like our FBV Express or Shortboard MkII pedals.
Here's a tutorial that shows you how to do that:
http://line6.com/community/docs/DOC-2076
Line6Miller
Re: RE: Please help...
by kuk3r on 2011-03-09 05:48:18.0490
And latency between click on controller and switch in POD farm?
responds it immediately without latency ?
RE: Please help...
by ricksox on 2011-03-09 09:03:00.1440
There's always some latency. In honesty, it may be too much latency for live use. This is something we have a bug logged for and hope to improve in future releases of POD Farm.
Line6Miller
by kuk3r on 2011-03-15 05:38:35.7420
Does it go with a footswitch to turn on and off bypass? Without Latency?
For example: I play through spinnal puppet.
                        Now I want to switch to clean, so i turn on bypass (with foot controller)
                       Now I will play only clean sound from my amp
Will it work this way? and in the reverse process too?
RE: Please help...
by Line6Hugo on 2011-03-15 08:53:34.5330
Yes, you can set a pedal to toggle an amp model on and off to toggle between the two via MIDI. IN POD Farm 2 there may be a small amount of latency, but you should give it a try to see if it works for you.
First, connect your Line 6 gear to Line 6 Monkey, and in the Optional Add-ons tab, click on Activate Purchase, and in the window asking for a license key, type in the word:
refresh
all in lower case letters. Then, check to see if there is a check mark next to POD Farm 2 in that window. If there is, you can download the POD Farm 2 software to use with the interface from the downloads page:
http://line6.com/software/
If there is NO check mark next to POD Farm 2 in that window, you will need to purchase the license:
http://line6.com/store/
Regards,
Line6Hugo
