Main :: POD HD
PodHD500 locked up!!
by dcoates20 on 2011-03-27 15:11:25.1680
While attempting to update the flash, my pod has locked up and is switching back and forth from the line 6 logo to the sound 1a.  I have no sound output.  I have tried to reboot with the < button and tried to restart with the "A" pressed.  I have lost all connectivity to computer so cant try to use Monkey to reflash.  Help!!
Re: PodHD500 locked up!!
by timowens on 2011-03-27 15:15:00.5540
Did you try to hold the down arrow? That's the one for 'UPDATE FLASH'.
by FrozenOzone on 2011-03-27 15:21:49.2950
Have you tried unplugging the USB from the 500 and starting the unit without the USB plugged in?  Mine looped unitl I unplugged the USB.  Now everything is ok but I wonder why it happened?
by dcoates20 on 2011-03-27 15:23:44.0550
Yes...this does bring up the update flash screen but since I have lost usb/midi connectivity, no way to update.  Was hoping there was a way to reinitialize the unit.
by dcoates20 on 2011-03-27 15:25:18.5400
Yeah....tried that as well.  Without anything hooked to computer, my screen continues to flash back and forth from the line 6 logo to 1A Monkeylord.  Nothing is working.
by flynvgtr1 on 2011-03-27 15:32:27.6120
This happened to me with my Variax attached. I unplugged the Variax and plugged it back in and it worked.
by dcoates20 on 2011-03-27 16:06:45.8630
No luck here.  If Line 6 cant tell me how to reinitialize the flash memory from the unit itself, I am out of options.
by gtrman100 on 2011-03-27 17:32:50.3500
Deleted post
by dcoates20 on 2011-03-27 20:16:55.7530
Problem solved by gtrman100's influence.  Although I had tried to reboot in the safe mode to reinstall the flash, nothing seemed to work.  Tried again and while the pod was in mode "update flash", I was finally able to run Monkey and everything is working.  Thanks to everyone, especially gtrman100.
by timowens on 2011-03-27 20:21:15.5450
Right on! Count yourself lucky because quite a few people have not been able to recover from this 'Logo Loop of Death'.
by dcoates20 on 2011-03-28 04:51:26.7500
You also helped me on the path but at the time, I could not connect to the computer.  I am not sure if I was being stupid or if some random event allowed me to finally connect with Monkey and update.  Thanks.
