Main :: Spider Valve
Cabinet Impedance
by pwbarber on 2011-05-22 17:02:08.0700
Hi all
I've just purchased a 16 ohm extension cabinet Orange classic(2x Vintage Celestions) which I am very happy with. I run it from my SV MK1. I understand that I cannot use the internal speaker in my SV 112 at the same time as the extension cabinet. Is this correct and if so is there a way around it? I haven't tried plugging in the internal speaker as well as the external cabinet as I do not want to fry the amp - I thought I 'd better seek some advice first. Your help would be appreciated
Regards
Paul
PS The Orange cab has 2 1/4 inch inputs
Message was edited by: pwbarber
Re: Cabinet Impedance
by Rowbi on 2011-05-23 00:59:51.0440
you would need an 8 ohm extension cab (not a 16 as you've bought),  then you can use that with the internal speaker into the two 4ohm outputs.
Apart form that, there's no way to do it without risking damage to your amp.
by pwbarber on 2011-05-24 16:41:27.4490
Thanks Rowbi - I thought that might be the case
Regards
Paul
