Main :: JM4 Looper
How can I save the Recorder Playback Levels,ie song/drums and mic/aux so I don't have to adjust them every time?
by airtime on 2011-05-31 09:55:59
When I load a new song from the SD card I have to readjust my output levels on the JM4 each time..How can I have them stay at the same level every time?  Is there a way to make my settings remain the same?  Thanks
RE: How can I save the Recorder Playback Levels,ie song/drums and mic/aux so I don't have to adjust them every time?
by Line6david on 2011-06-01 15:49:30
You will have to save the song to the SD card again in order to change these settings. i.e. the settings are stored when you save the song.
http://l6c.scdn.line6.net/data/l/0a0600726998490212ba88448/application/pdf/Spider%20Jam%20Advanced%20Guide%20%28Rev%20B%29%20-%20English.pdf
Thanks,
David
Line 6 Customer Support
Re: RE: How can I save the Recorder Playback Levels,ie song/drums and mic/aux so I don't have to adjust them every time?
by airtime on 2011-06-01 17:44:00
Thanks..I kinda figured it out...The info is saved when you save it on a SD card or when you save it to the internal memory....thanks again...
by airtime on 2011-06-01 17:44:54
But.......you can't have the JM4 default to that setting..right?
by Kneehow on 2011-06-03 09:41:53
Correct.
