Main :: M5 / M9 / M13
where would i put a micro pog with an m13 in the 4 cable method
by horbag on 2011-07-06 11:07:00.5010
where in the chain would i put an ehx micro pog if im using the m13 in 4 cable mode do i put it in the effects loop if so how do i connect this up
RE: where would i put a micro pog with an m13 in the 4 cable method
by Line6Don on 2011-07-07 11:38:26.4290
Hey horbag,
There is not a right or wrong way to connect this type of effect with your M13. Connecting it before the M13 sounds like a good idea to me so that you can use the POG to change your guitars sound, and then run it through the m13 and apply effects to it. If you were to put the POG after the M13, the added effects could interfere with the pitch tracking on the POG. I would not recommend using the POG in the effects loop of the M13, again based on the fact the any added effects could interfere with the POGS ability to track pitch.
