Main :: POD X3
Setting up vocals with POD X3 live with 2 channels
by Novotny on 2011-07-16 13:39:43.0430
How do you split the vocal and guitar outputs? We are trying to run the vocals through the PA (tone 2) and the bass (tone 1) through the amp/cabinet but the vocals are still bleeding through the bass amp.
We have tried panning each channel, one to left and one to right but they still both come through both outputs. Any help would be appreciated. Thanks for reading!
Re: Setting up vocals with POD X3 live with 2 channels
by silverhead on 2011-07-17 12:18:49.7260
Could be a couple of things........
There is a known glitch in the X3 panner where some tone bleeding occurs at the full (100%) L/R pan positions. Try backing of the panning for each Tone just a tick to slightly less than full L/R; that should stop the bleeding.
Also, depending on what outputs you are using you might choose to mute the Tones. Often, a setup like you describe will work best if you use the XLR Direct outputs to the PA/mixer for vocals, and the 1/4" Live outputs to the amp. In that case you would mute the guitar Tone in the XLR Outputs page, and mute the Mic Tone in the Live Outputs page. In this case you need not pan the Tones to mono; you could leave the Pan position for each Tone in the middle and retain dual stereo channels.
Finally, make sure your Inputs are set up properly: Guitar for Tone 1 and Mic for Tone 2.
by Novotny on 2011-07-22 23:13:27.1730
Hi thank you for the info. We tried first offsetting the panning just a little bit to help with the bleed but that didn't work. Next we tried the muting and that worked perfect! Until.....we tried changing the voices for either of the tones. It's my bass players' pedal and we want to run the vocals through it too. As soon as we try changing the voices on Tone 1 (bass guitar), it goes back to normal and turns the mute off. We also tried locking tone 2 and then switching the voice on tone 1 and it still affected tone 2. the bass would then be heard through the PA. Also, it changes the input settings anytime we try to change the voice. Input 1 is guitar, input 2 is mic (xlr). We did mute tone 2 in the 1/4" output and muted tone 1 in the xlr (direct) out and it worked perfect (panning was centered for all) until we tried changing the bass sound. What are we missing? How do we keep the two separated  while changing the tones? Every time we change anything it goes back to default. Also, whenever my bassist uses the wah pedal is decreases the volume on the vocals...is it possible to use the wah effect while using the x3 for vocals at the same time? Any help/advice is greatly appreciated. Thank you much
by silverhead on 2011-07-23 07:50:56.1720
Novotny wrote:
.... What are we missing? How do we keep the two separated  while changing the tones?
These Output settings (like Mute) are not global settings. You must reset them for each preset.
Also, whenever my bassist uses the wah pedal is decreases the volume on the vocals...is it possible to use the wah effect while using the x3 for vocals at the same time? ....
In Tone 2 (your vocal tone) edit the VOL pedal effect. You can set the Min/Max levels of the pedal range to the same value. This negates the effect of moving the pedal. Alternatively, you could simply turn OFF the VOL effect in the signal flow view for Tone 2. In the former case set the min/max level at the point that provides the best volume level for your vocal tone. In the latter case you would need to rely only on the Channel volume to get a good level; if you can't get a good level using only the Channel volume, then you should use the former method.
