Main :: FBV MkI / MkII Controllers
how do you switch from volume to wah on the mark2 shortboard?
by jak_E_lee on 2011-08-09 16:20:48.4270
i just got my new spider 4 (75) today and the FBV mk2 along with it but how do you change from volume to wah?
Mine is on volume and the volume led is on but really i want to activate the wah
Totally fantastic ,brilliant amp...especially the no more tears sound
RE: how do you switch from volume to wah on the mark2 shortboard?
by Line6Don on 2011-08-10 11:18:51.2290
Hey jak_E_lee,
Can you please register your Line 6 gear to your User Account by following the link below:
http://line6.com/account/registergear/
Many Line 6 unit serial numbers begin with 21 in parenthesis, while the instruments will have the serial number on the back of the headstock, while effects pedals and audio interfaces will have the serial number on the bottom of the unit. Please see the following document for more information on serial numbers and registration:
Line 6 Product Registration F.A.Q.
http://line6.com/community/docs/DOC-4283
To engage the Wah on the FBV MKII series pedals, simply press down firmly on the toe end of the expression pedal. Make sure that you have the pedal on the ground, and don't be scared to push down on the pedal. It is designed to not trigger as easily as a traditional wah type pedal, so that you can do back and fourth sweeps with the pedal without accidentally turning off the wah.
