Main :: Spider Jam
FBV Express MK II Board and Spider Jam default setting
by velobob on 2011-08-16 17:39:39.8590
So I'm wondering....is it possible to "set" my Spider Jam so that the default FBV-express board setting is set to "Jam Control" whenever I power up the amp?
The way it currently operates is such that it always defaults to "normal", so that in order to do a recording, I always have to manually reset the FBV control settings.
Re: FBV Express MK II Board and Spider Jam default setting
by Rantobi on 2011-08-16 18:21:29.2260
This has been my experience as well.  This setting cannot be save..... would be nice though.
In fact I would like to add that in my humble opinion given that the main purpose of this amp seems to be to be able to record and "Jam" along to enhance your experience and further learng that at the very least this setting would not be so buried so far down the menu.
Randy
by velobob on 2011-08-16 18:23:52.2370
wonder if there is any way to change the setting?...would like to hear from Line 6 tech support
and yeah, it certainly is buried in the menu!
by daydreamin7677 on 2011-08-17 09:25:22.3520
This has been a topic of debate on here for some time. I think it sucks that you are not able to leave it in jam mode and if I remember correctly you actually could do this befor the version 2.9 upgrade. I have an FBV MKII Short board, all I do to activate the looper is hit the Function1 switch and I'm looping with my feet so its really not that inconvenient. Hope this helps.
RE: FBV Express MK II Board and Spider Jam default setting
by Line6Don on 2011-08-18 10:54:13.9300
Hey velobob,
This setting will need to be enabled each time you turn on the Spider Jam.
If you would like to be able to save this as a preference on the amp, please submit a feature request for this using the link below:
http://line6.com/company/contact/productfeedback/
Thank you.
by Line6Don on 2011-08-22 10:02:56.2270
Hey velobob,
This ticket is being closed due to lack of response within 48 hours. If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
http://line6.com/support/community/support/
For more information about using the Online Technical Support System please review our FAQ at the link below:
http://line6.com/support/docs/DOC-1451
