Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
How do i download a tone and save it on Pod XT Pro?
by Benbjj on 2011-08-22 23:55:25
Thanks!
Re: How do i download a tone and save it on Pod XT Pro?
by Triryche on 2011-08-23 06:35:13
Go here for tones:
http://line6.com/customtone/
Thenyou would need to use Gearbox to download the tone to your xt.
If you do not have Gearbox you can dl it along with the required drivers here:
http://line6.com/software/
RE: How do i download a tone and save it on Pod XT Pro?
by Line6Don on 2011-08-23 15:26:27
Hey Benbjj,
In addition to downloading and install the latest version of GearBox 3.72, you will need to install the Line 6 drivers for your operating system as well:
Windows Drivers 4.2.4.4:
http://line6.com/software/readeula.html?rid=3987
MAC Drivers : 7.0.9
http://line6.com/software/readeula.html?rid=4170
Once the drivers are installed you will need to install the Line 6 Monkey application from the links below:
Windows Line 6 Monkey 1.41:
http://line6.com/getrelease?rid=4114
MAC Line 6 Monkey 1.41:
http://line6.com/getrelease?rid=4115
Once Line 6 Monkey is installed, remove any additional unnecessary USB and firmware devices from your computer when troubleshooting this issue. Make sure to connect it directly to a USB port and not a USB hub, extension, or keyboard of any kind, preferably connect it to a USB port on the rear of computer. Try using additional USB cables and every USB port available until you are able to launch Line 6 Monkey and detect the device.
Once Line 6 Monkey is launched apply any updates that are available until you have a green check next to each component.
Once all of this software has been installed you may launch GearBox and use it to open the tone files that you downloaded from CustomTone.com.
Re: RE: How do i download a tone and save it on Pod XT Pro?
by Benbjj on 2011-08-23 21:29:02
Thanks guys! Will get on it!!!
