Main :: Lowdown
Lowdown 110 speaker output distortion
by juanho on 2011-10-22 05:48:25.4290
Hello, I have a line 6 lowdown 110. There's a distortion at the speaker output. It happens in all the presets and is more noticeable at low and mid volume levels. If I turn down the bass frequencies, there's almost no distortion but it comes when the low frequencies are present. In the DI and the Headphones out the sound is ok, no problems. As I'm in a country with 220V AC I'm using an AC converter 220/110V, 1000W. I've tried with others converters, I've made a reset (holding down "clean" for 5-8 seconds when I turn on the amp) but the problem still remains.
Please somebody can help me? Thanks.
RE: Lowdown 110 speaker output distortion
by Line6Don on 2011-10-24 11:44:03.0840
Hey juanho,
If the speaker is producing a distortion on the low end response, then the speaker itself could potentially be damaged. I would suggest that you have a local Line 6 Service Center in your region assess the amp for you. The Line 6 Service Center in Singapore can be reached at the contact info below:
City Music Co. Pte Ltd.
1, Sophia Road, #02-12/13
Peace Centre
228149
+65 63377058 (phone)
+65 63385919 (fax)
hoeyl@citymusic.com.sg
Re: RE: Lowdown 110 speaker output distortion
by juanho on 2011-10-26 09:14:38.2220
Thank you Line6Don.
I'm not anymore in Singapore and I think is very hard to get the original part here in Argentina.
Can you send me some replacement speaker from other brands (for example eminence, jbl, rcf). Please specify brand and models.
This will be of great help.
Thank you again!
Ok lah
by darealagentp on 2011-10-28 15:31:46.3220
Here are some good options: http://www.usspeaker.com/10.htm
