Main :: POD X3
POD X3 Presets shuffle?
by adam22228 on 2011-11-09 14:48:05
What is the best way to shuffle & rename POD X3 presets.  I have tried using the screen & dials but renaming the tones is a pain.  I've tried in gearbox but can't get them to save on the POD X3.
There must be an easy way?
Thanks in advane.
Adam.
Re: POD X3 Presets shuffle?
by silverhead on 2011-11-09 14:53:28
Gearbox is certainly the easier way - just drag/drop tones in the Hardware Memory window.
To load/save the rearranged set to the X3 device use the Gearbox PUT ALL command in the top area of the main Gearbox window.
by adam22228 on 2011-11-09 15:19:23
Thanks silverhead.  I know I said shuffle... (sorry) but drag & drop just swaps the presets.  What do I need to do to copy an existing preset & paste over one I don't use? (then I tweek & resave)
Thanks again,
Adam.
by silverhead on 2011-11-09 16:12:21
Use CTRL drag/drop to copy/replace.
by Line6david on 2011-11-10 11:36:35
This should help:
http://l6c.scdn.line6.net/data/l/0a06007259ac496524903f119/application/pdf/GearBox%203.7%20User%20Manual%20%20%28Rev%20C%29%20-%20English.pdf
Page5.13
Thanks,
David
Line 6 Customer Support
