Main :: POD HD
should i get pod if i have a spiderjam
by OnMyWay5555 on 2011-11-13 09:10:56
hi pleasee help.... i am going to get a spider jam 75w and since it has alot of effects built in, will it be a waste to by a pod also or is the pod different.
andd do you have any suggesstons of add ons to get the most of the amp
Re: should i get pod if i have a spiderjam
by TheRealZap on 2011-11-13 09:37:53
it might be a bit of duplication... i would recommend that you spend the extra money on the FBVMKII to get a bit more out of it... it will also work on a pod if you decide to get one down the road....
i'd stick with just the jam until you outgrow it or want more options.
by OnMyWay5555 on 2011-11-14 08:50:50
thanks man really helped
Re: RE: should i get pod if i have a spiderjam
by Kneehow on 2011-11-15 11:27:54
I agree with Zap... you should be able to develop your playing with the Spider Jam's onboard amp/effect modelling for now.
If and when the time comes and you wish to really get into programming your own sounds for recording/live usage, the POD HD500 will be there for you to test drive.
