KB37 MIDI issue
by TerraExcessum on 2011-11-14 14:37:53.4980
Hi folks. I'm having problems getting my KB37 to work as a MIDI controller. It was fine up until about a week ago and I can't work out what has changed. I usually use it with Zeta+2, but now I load it up, try to play and get nothing. I tried activating it in the MIDI tab but a popup appears saying "Error opening MIDI device, device might be in use".
I'm still learning my way around this new fangled piece of technology they call a computer, so any suggestions as to where to look would be hugely welcomed.
Re: KB37 MIDI issue
by Triryche on 2011-11-14 15:02:20.9640
Check to make sure your drivers are current.
Run the newest version of the Line6 Monkey.
http://line6.com/software/
Does the Monkey see the KB37 and are there green ticks for drivers/firmware?
Re: KB37 MIDI issue
by TerraExcessum on 2011-11-14 22:34:12.0070
Hi Triryche.
Yep. The ever-wise Monkey tells me that the drivers are all up to date and all the appropriate green ticks are there. I treid re-installing the most recent driver but that hasn't helped.
Re: RE: KB37 MIDI issue
by Line6david on 2011-11-15 14:59:01.9540
  This does sound like a driver related issue. What other devices do you have connected to your computer that use MIDI?
  Thanks,
  David
  Line 6 Customer Support
by TerraExcessum on 2011-11-15 22:30:31.6620
Hi David.
My KB37 is the only MIDI device I use.
Re: KB37 MIDI issue
by Triryche on 2011-11-15 22:38:09.5520
Robb,
I have never used Zeta. Are you running this as a standalone or as a VST in a DAW?
Re: KB37 MIDI issue
by TerraExcessum on 2011-11-15 22:41:52.4490
I usually use it as a vst in Cubase 5 but it can also be used as a stand alone. I've tried a couple of MIDI programs and they all come up with similar reasons for not doing anything so it must be something to do with the KB37. (I assume...)
Re: KB37 MIDI issue
by Triryche on 2011-11-16 06:05:11.9710
Havre you tried this in Reaper by any chance?
If you haven't, (and I know it is a pain) maybe you could run the trial version as I can confirm the settings in Reaper.
Re: KB37 MIDI issue
by TerraExcessum on 2011-11-18 11:46:21.6800
Apologies for the delay. I had a couple of days out of the house for a change!
I've never used Reaper. Once I get a few minutes spar I'll get the trial and have a look.
In the meantime, if anyone else thinks of anything, all suggestions are thoroughly welcomed!
Re: KB37 MIDI issue
by TerraExcessum on 2011-11-20 02:36:13.8340
Hi Tryryche.
I installed the trial version of Reaper and managed to get my KB37 to work in it, so I tried completely uninstalling and reinstalling Zeta which has worked for that as well. It looks like all my MIDI programs just forgot what controller I'm using, so I'm going to do the same thing with those as well and hopefully all will work out fine...hopefully.
If not, I know where to come for more help. Thanks very much
Re: KB37 MIDI issue
by Line6Tony on 2011-11-23 08:59:10.0980
With the KB37 working in Reaper, and it looks like Zeta, you may have some configuration issues to work out on your system. With that, we will mark this thread answered.
Re: KB37 MIDI issue
by FingerKingJack on 2012-01-13 03:05:47.7210
Hi Tony,
I got the Line6 KB37 just after christmas, and I've been struggling ALOT with it since plugging it in.
my biggest issue is that:-
1. I can't get it to work on Reaper (which is my preffered software).
I keep just getting a very unhelpful message saying that the MIDI input could not be opened.
Now and I don't know this is a problem with Reaper or the KB37, but if you could shed some light on it that would be great.
2. I'm getting to grips with the Ableton LiteLive software, but the delay inbetween the time it takes for me to hit my strings and it to register on my PC is incredibly off putting.
I've turned the MS Latency buffering down as low as it can go without making my guitar sound like a frog vomitting.
Once again, if you could help me out here at all, that'd be great
Re: KB37 MIDI issue
by Triryche on 2012-01-13 05:28:00.8340
FKJ,
Post a new thread and mark it as a question.
Since this thread is answered, it is virtually invisible to official Line6 reps.
