Main :: POD HD
HD500 Wah help please.
by Gandalf5150 on 2011-11-21 05:08:37.2270
When I add a wah to a patch, then select that patch, the wah is already activated and I have to click the toe switch to turn it off.
I accept I'm not very good at building patches, but I can't seem to work out how to add a wah which needs to be toe switched ON?
Any help would be much appreciated.
NB...how many are using Glenn DeLaune's setting on their wahs?
See link, it's a great tip.
http://www.youtube.com/watch?v=F6I6WCufEtk
Re: HD500 Wah help please.
by jimsreynolds on 2011-11-21 06:05:14.5880
Should be pretty simple.  Just turn the wah off with your toe and save the patch.
If there is any confusion with HD Edit then just press the save button on the HD twice after toggling the wah off.
Any good?
by Gandalf5150 on 2011-11-21 08:17:06.0740
Sorry, no that still isn't working. I think maybe my default setting is NOT allowing the toe switch to turn it on/off?
Toe switch just alternates from EXP1-EXP2
How do I access toe switch settings?
Edited...all sorted. It was indeed the toe switch not being assigned to turn the wah on/off.
Can't believe that isn't the default setting?
Thanks for your help.
