Main :: POD X3
How can I get back my preset tone workable in PODx3 live?
by arifinguitarman on 2011-12-04 09:46:39
I'm using PODx3 Live. I've reset my PODx3 live. Then I update my firmware and flash. After that all of my User tone are showing into the screen but I cann't play one of those because all are sound less. When I go to song folder, 5160 tone of 1 is soundless but next  tone Anthem (Dist) is ok. And most of the tone are soundless.
Please help me to come out from this problem.
Re: How can I get back my preset tone workable in PODx3 live?
by silverhead on 2011-12-04 09:54:31
Check your inputs on the presets that are silent. Some presets are designed to use the Microphone input - not guitar. They are designed for vocals or for mic'ing an acoustic guitar.
by arifinguitarman on 2011-12-04 10:33:23
im new user so i dont know how can i check  please healp me
by silverhead on 2011-12-04 10:36:54
Press the Inputs button on the X3. This is where you assign your input sources for Tone 1 and Tone 2. You set it to Guitar if you are using a guitar, to MIC if you are using a mic, etc. When you check the inputs on a factory preset, if it says MIC then the preset is designed to be used with a microphone input. You will not hear your guitar.
by arifinguitarman on 2011-12-04 10:51:04
cheaked and it showing Tone 1 Guitar +vx 1 / Tone 2 same is there any problem ? i cant get any sound here :-?
by silverhead on 2011-12-04 12:50:37
How are you monitoring your sound? Try using headphones first - is there any sound there? Are you using speakers or a guitar amp for the sound output?
by arifinguitarman on 2011-12-05 04:12:14
yes i m using guitar amp ....please healp me
by silverhead on 2011-12-05 20:04:38
Try using your X3 headphones output - do you hear sound there? This is important troubleshooting information - please try it.
by arifinguitarman on 2011-12-05 23:49:46
no sound .. recently i found that if i press wah pedal that means if wah on then im getting sound form every tone but if wah off then soundless ... what can i do ????
by Kneehow on 2011-12-09 10:39:29
If you have a backup of your presets (use Monkey's "Backup and Restore" option to create a bundled .zip of all the patches currently on your unit), I'd say do another re-flash of the X3 Live but this time, answer "No to keeping existing patches". In other words, do a true factory reset and let Monkey put the newest factory default patches into your unit and re-test the audio output behavior of the unit.
There could've been a problem with a previous patch you had in the unit or perhaps the flash process.
by arifinguitarman on 2012-01-13 05:33:35
Thnks ALL ..Problem Solved :-
This is very normal Problem ..Most of user facing it So Why Line6 Dnt give us the
materials I Mean Optical sensor ? WHy they told send it line6 reapire centre ?
I Never Use Line6 next time & I Never tell  anyone purchase line6 product
Becuse Line6 dnt take customer care
an
angry user
