Main :: POD X3
Control by foot
by Vostor on 2011-12-04 10:55:36.0920
Now that I connected an FBV footcontroller, I find that my problem is not midi but X3!!
Also with the FBV, as with my midi footcontroller, the stompbox or modification do not work on tone 2  !!
I'm afraid there's a problem with my X3 pro!
Re: Control by foot
by darealagentp on 2011-12-08 09:45:44.3770
I just pulled out our POD X3 Pro w/ Flash 2.10 and USB Firmware 1.00 installed and connected both an FBV Shortboard and an FBV Shortboard MKII.
When you have a "Dual Tone" patch active and select Tone 1, do your Stomp/Mod/Delay/Reverb bypass switch functions work correctly?
Then, switching to Tone 2, are you saying that these same switches are not engaging or bypassing those corresponding parameters?
If so, I'd re-flash the POD X3 Pro again. Back up your patches first in Monkey using Backup/Restore, but when you re-flash choose to "not keep existing patches".
Also, try a different CAT-5 network cable to connect your FBV controller to the X3 Pro.
RE: Control by foot
by Line6Don on 2011-12-13 17:19:41.7500
Hey Vostor,
Line6Perry's answer above is correct. I have marked the answer that is correct for your question, please help out the community by marking other suggestions that were helpful to you as "Helpful Answer".
If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
http://line6.com/support/community/support/
For more information about using the Online Technical Support System please review our FAQ at the link below:
http://line6.com/support/docs/DOC-1451
Thanks!
