Main :: POD X3
How can i get back sound in my pod x3 live
by arifinguitarman on 2011-12-07 03:50:23
I'm using PODx3 Live. I've reset my PODx3 live. Then I update my firmware and flash. After that all of my User tone are showing into the screen but I cann't play one of those because all are sound less. When i select wah on / press  pedal for select wah then im getting sound form every tone when i selct wah off then all tone are soundless ..then im trying to re calibrate but im failed becuse the valeu is not change its show 0 ..
Please help me to come out from this problem.
Re: How can i get back sound in my pod x3 live
by silverhead on 2011-12-07 07:51:55
After you engage the Wah and you are hearing sound, does the wah respond to the pedal movement? In other words, do you hear the wah effect when you move the pedal?
If not. that suggests that the toe switch of your pedal is working but the ability to detect pedal movement is not. This will require a trip to your local Line 6 service centre for a hardware repair:
http://line6.com/service_centers/
If">http://line6.com/service_centers/">http://line6.com/service_centers/
Ifyou are able to hear the sound responding to the wah effect as you move the pedal, then there is some other problem. Let us know.
by arifinguitarman on 2011-12-07 10:16:12
thanks a lot .
no wah does not respond the pedal movement .... im writing form bangladesh here is no line6 service centre .here only  dealer , without dealers can i buy it by online ? please tell me
by silverhead on 2011-12-07 10:33:07
I know you mentioned you had recalibrated your pedal but it is definitely worth trying that again. Here are the procedures (see bottom of page in this document):
http://line6.com/support/docs/DOC-4609
If">http://line6.com/support/docs/DOC-4609">http://line6.com/support/docs/DOC-4609
Ifrecalbration fails repeatedly then your X3 needs servicing. Call either of these numbers to start:
Line 6 - North America
Line 6, Inc.
26580  Agoura Road
Calabasas, CA 91302-1921
Main Phone#: (818) 575-3600
Main Fax#: (818) 575-3601
Line 6 - Europe
Line 6, Inc.
The POD
Clifton House
Butler's Leap
Rugby, Warwickshire
United Kingdom, CV21 3RQ
Telefone: +44 (0) 1788 566 566
Fax: +44 (0) 1788 566 529
by silverhead on 2011-12-07 10:49:41
Here are some old threads that discuss this issue. If your X3 is no longer under warranty and you want to attempt a self-repair, you can try opening the pedal up and adjusting the internal foam ring that acts as a light block.
http://line6.com/support/thread/5057
http://line6.com/support/thread/5057">http://line6.com/support/thread/5057
_jive_internal="true" class="loading active_link" href="/message/325908#325908" title="http://line6.com/support/message/325908#325908
You">http://line6.com/support/message/325908#325908">http://line6.com/support/message/325908#325908
Youcould also search this forum for other relevant threads and information.
by arifinguitarman on 2011-12-07 11:31:13
thanks for your special kindness ....i ll inform you later
by arifinguitarman on 2011-12-14 04:54:31
i want to know user"s email id but how  ?
by silverhead on 2011-12-14 05:11:40
If you are talking about a forum user, only they can disclose their email address if they wish. Each user's personal profile permits them for privacy concerns to disclose their email address publicly, or not. If a user has elected to keep this information private then you will not see it, and cannot obtain it.
by arifinguitarman on 2012-01-09 09:59:07
i need this pcb dagram is it possible too get ?
by silverhead on 2012-01-09 10:46:26
Diagrams of the internal workings of Line 6 products is proprietary information. Line 6 does not release this information to the public. Only authorized Line 6 service centres have access to this information.
by arifinguitarman on 2012-01-10 05:51:46
ohh by the way you know my device problem ...if i send it servicing centar (lin6) have you any idea its cost how much ?
by TheRealZap on 2012-01-10 06:06:23
service centers are independent, and set their own prices... you'd have to call them and ask.
