Main :: DT50/DT25
extra speaker cab to a DT25 112 combo
by RobbieS on 2011-12-14 02:14:06.2110
Does anybody know if its possible to connect an extra speaker cab to a DT25 112 combo?
Re: extra speaker cab to a DT25 112 combo
by Nick_Mattocks on 2011-12-14 03:41:47.9110
Yes it is.  The Line 6 DT-25 extension cab that also matches the DT-25 head would be the obvious partner, but any 8 Ohm speaker cab would be fine.  Simply disconnect the internal speaker and plug it into one of the 4 Ohm outputs and then connect your external 8 Ohm speaker cab to the other 4 Ohm output.
HTH
Nick
by Rowbi on 2011-12-14 07:18:49.6240
NIck's right +1.
just remember that if you then want to use the combo on its own again to move the internal combo speaker back to one of the 8 ohm outputs on the amp.
Cheers
Rowbi
