Main :: Sonic Port / Mobile In
Mobile pod to garageband
by alma1948 on 2011-12-16 03:50:38.0140
Can I get the guitarsound from mobile POD in to garageband in my IPAD ?
And if how do I do it ?
What is the meaning with compability mobile in and garageband ?
Mobile in will function with all DAW:S ?
Thank you
Re: Mobile pod to garageband
by TheRealZap on 2011-12-16 05:32:53.2310
this should clear things up for you:
http://line6.com/support/docs/DOC-2501">http://line6.com/support/docs/DOC-2501">http://line6.com/support/docs/DOC-2501
by silverhead on 2011-12-16 06:16:30.4930
No - the Mobile App does not run simultaneously with Garageband, and its sounds are not available for recording in Garageband. The Mobile In can be used as the audio interface to Garageband as the document zap linked you to describes.
by nicoexp on 2012-02-06 03:00:53.5240
I understood the multitasking trouble... but many amp simulation softwares usually support the direct "copy" and "paste" of recording audio tracks.
In such a way, you can record in your POD mobile app and then import (using copy and paste functions) the track into a multitrack application (for example in garageband).
Does the mobile pod app support this king of interaction?
Just another question: does the mobile app support the copy and paste of the "dry" track (the track without any kind of amp processing...)?
Thank you for the support
