Pod Farm Protools plugs are dry ! HELP i'm going to be crazy
by borisbeziat on 2011-12-16 04:00:31.6330
My win7 x64 is up to date, everything is ok with my "toneport di gold",
every plug i open in protools see the DI and all the packs but the sound is dry,
the pod farm 2.5 standalone is working fine.
I try to fix this problem since monday.......!
HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEELP
Why can't i refund to ilok version ? The tone port di gold was at a upper price than the ilok version when i baught it, and of course the ilok was not existing at this time.
Thank you.
Re: Pod Farm Protools plugs are dry ! HELP i'm going to be crazy
by borisbeziat on 2011-12-16 09:17:49.3830
Line6 support, i need a ticket !
by borisbeziat on 2011-12-16 09:52:24.8350
Some are working.... but not all the authorised packs i have in the di gold, just 2 or 3 reverbs for exemple.
I need a ticket !
by borisbeziat on 2011-12-16 10:24:50.0590
I think i need a ticket
by borisbeziat on 2011-12-16 14:45:22.5920
i need a ticket !
thank you
by Line6david on 2011-12-20 16:53:01.9200
Completely uninstall POD Farm 2.50, then, download and install POD Farm 2.51 from the Line 6 downloads page.
An error message pops up at startup with the following:  Pro Tools could not load the following plug-ins either because no valid authorization could be found, the iLok key was not connected or the plug-in was damaged.  It also lists the POD Farm 2 and POD Farm Elements plug-ins below the message.
This is a Windows-based problem and seems to be an issue if Microsoft Visual C++ Redistributable is not updated or installed properly on the computer system. Using Windows Update to install/update Microsoft Visual C++ Redistributable so that POD Farm 2.5 can have access to the libraries it needs to run correctly usually fixes the problem.
If you are using a Custom Plug-in folder location for your DAW, make sure to delete the old POD Farm 2 and POD Farm Elements plug-in files from that location, and move the new POD Farm 2.51 plug-in files to that same location.
  • On Windows Vista/7, they are located in:  C:\Program Files(x86)\Line6\POD Farm 2\VST\Line 6
Thanks,
David
Line 6 Customer Support
