Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
when I go to download tones using Line 6 Edit, I get a java error message and can't download anything
by peterandjuralove on 2011-12-28 20:42:34
Here's what I'm using:  Pod xt Pro v3.02, 27"imac 2.93GHz Intel Core i7 OS X v 10.6.8
I get the following error message whenever I try to go online to download tones using Line 6 Edit.
Any clues?
Here's the error message:
An exception was caught.
java.lang.ClassNotFoundException: cmn.l6java.browser.L6NativeBrowser.L6NativeBrowserMac
App info: Line 6 Edit 3.04.0 release - build 102 - Fri Jan 28 09:43:31 PST 2011
Date: 12/26/11 11:38 PM
In thread: Thread[AWT-EventQueue-0,6,main]
OS: Mac OS X (10.6.8 i386)
Java VM Version: 1.6.0_29
Stack trace:
          at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
          at java.security.AccessController.doPrivileged(Native Method)
          at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
          at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
          at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
          at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
          at java.lang.Class.forName0(Native Method)
          at java.lang.Class.forName(Class.java:169)
          at cmn.l6java.browser.L6NativeBrowser.L6NativeBrowser.CreatePlatformBrowser(Unknown Source)
          at cmn.l6java.browser.L6NativeBrowser.L6NativeBrowser.<init>(Unknown Source)
          at line6editbase.app.L6ToneTransferBrowser.<init>(Unknown Source)
          at line6editbase.app.L6ToneTransferBrowser.ShowInstance(Unknown Source)
          at line6editbase.app.L6EditorApp.ShowToneTransfer(Unknown Source)
          at line6editbase.app.L6EditorApp$6.run(Unknown Source)
          at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
          at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:677)
          at java.awt.EventQueue.access$000(EventQueue.java:85)
          at java.awt.EventQueue$1.run(EventQueue.java:638)
          at java.awt.EventQueue$1.run(EventQueue.java:636)
          at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
          at java.awt.EventQueue.dispatchEvent(EventQueue.java:647)
          at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
          at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
          at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
          at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
          at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
          at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Re: when I go to download tones using Line 6 Edit, I get a java error message and can't download anything
by TheRealZap on 2011-12-28 21:03:56
the easiest way to avoid java with an XT is to use gearbox instead of line6 edit.
you may need to reinstall gearbox to set your file associations.
by Line6david on 2011-12-30 15:13:28
+1 to Zap,
At this point, I would suggest giving Gearbox a try:
http://line6.com/software/index.html
Gearbox">http://line6.com/software/index.html">http://line6.com/software/index.html
Gearboxis not JAVA based so you should be able to save and load your tones using that application.
Thanks,
David
Line 6 Customer Support
RE: when I go to download tones using Line 6 Edit, I get a java error message and can't download anything
by Line6Don on 2012-01-05 16:18:02
TheRealZap's answer above is correct. I have marked the answer that is correct for your question, please help out the community by marking other suggestions that were helpful to you as "Helpful Answer".
If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
http://line6.com/support/community/support/
For more information about using the Online Technical Support System please review our FAQ at the link below:
http://line6.com/support/docs/DOC-1451
Thanks!
