Main :: POD HD
External midi bpm tempo available for HD500?
by CthulhuChaos on 2012-01-09 20:45:33.8010
I use ableton live to midi sync my external delays and other rack units to bmp tempo. Can I send a signal via MIDI cable to a global or specific channel (I use ch1 for this) to have all the delays modulate based on tempo changes?
I'm looking at buying a HD500. I record direct now and use amplitube, but hate fiddling with a mouse while trying to jam. I am planning to go guitar -> sansamp para di -> mixer (recorded direct) and HD500 (recorded "dirty" via spdif outputs at 24bit 96k)
I have the original POD and a DL-4, if you could help me out with this specific question, I'll surely be buying another one
edit... never mind, read other discussions and also see a 1.40 firmware update solves any issues. sold! (once i have hte monies)
Re: External midi bpm tempo available for HD500?
by gregr on 2012-01-09 20:58:21.0780
As far as I can tell you can only adjust the tap tempo rate through sending periodic CC messages just as you would tapping your foot on the HD500 itself.
by CthulhuChaos on 2012-01-09 21:07:31.6660
I can handle tapping a tempo manually. Ableton sends a signal for the initial bpm. If the bpm changes within a song, another signal is sent.
It looks like it can handle an external tempo so i should be set. I have a DL-4 so I'm used to tapping tempos
