Main :: GearBox
GuitarPort gearbox hears guitdar but no sound.
by The_Airow on 2012-01-17 10:39:17.6410
Installed GuitarPort using instalation CD and updated driver found on Line6.com when plugged in the light glows in recognition of sound from the guitar but headphones plugged in to the back don't hear anything. Additionaly the software doesn't show any signal or output sound and the tuner doesn't either. When trying to load a preset tone an error mesage pops up saying,
"DSP failed to load model correctly. You may not hear the selected model.
Reason: Hardware service unavailable or could not be opened"
I'm running windows 7 and I'm not sure if my laptop doesn't run the software correctly or what's up. The system requirements says I have 0MB of RAM and I have PIO enabled on one of my drivers "MATSHITA DVD-RAM." Please help and thank you for your time.
Re: GuitarPort gearbox hears guitdar but no sound.
by The_Airow on 2012-01-17 18:34:39.3420
Sorry its not a gear box but a guitarport.
by Line6Don on 2012-01-26 10:49:53.4180
Make sure that you are running GearBox 3.72, it can be downloaded from the link below:
http://line6.com/software/readeula.html?rid=3121">http://line6.com/software/readeula.html?rid=3121">http://line6.com/software/readeula.html?rid=3121
Make sure not to install the drivers that come bundled with it, in case you have I would suggest that you use the Line 6 Uninstaller located at the location below to remove your currently installed Line 6 drivers:
Windows 7/Vista  -  C:\Program Files(x86)\Line6\Tools -  Line6Uninstaller
Make sure to disconnect any of your Line 6 USB devices prior to starting the uninstaller. Make sure to only check the boxes at the bottom of the list that are related to the Line 6 drivers, and proceed to uninstall them. Once they are removed, restart the computer. Upon restart download the latest Line 6 Window Drivers from the link below:
Windows Drivers 4.2.5.1:
http://line6.com/software/readeula.html?rid=4399
Make sure not to connect your Line 6 USB device until prompted to so at the end of the installation process. After connecting it, make sure and look towards the Windows system clock for a notification that Windows has detected your device and has successfully installed the drivers before moving forward. If you do not receive this notification message, make sure to try reconnecting the Line 6 hardware to each available USB port until you have exhausted all available USB ports. Once Windows has detected it, you can relaunch GearBox and make sure to configure GearBox to use the GuitarPort hardware, this is configurable from the hardware tab of the preferences menu.
RE: GuitarPort gearbox hears guitdar but no sound.
by Line6Don on 2012-02-01 10:24:06.9380
It has been at least 72 hours since we've heard from you. We're going to assume your question has been answered. If it has been answered, please award points to whoever was helpful and/or answered the question.
In the event your issue has not been resolved, I created a support ticket for you so we can continue to communicate. Please respond to the ticket. Thanks!!
Q: What is a support ticket?
A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link to the ticket when a Line 6 Support Representative responds to it. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support. Also, in your account, click My Account, then click Support Tickets to view the support ticket. Here’s a shortcut:
http://line6.com/account/tickets/view/
Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host, and also that your email account is receiving messages at all.
