Main :: Spider IV/Spider Online
Cannot connect spider edit
by tbamorgan on 2012-01-17 17:11:17.6680
I can connect the fbv shortboard to my laptop but i the line6 monkey and the spider iv edit does not show any line 6 devices.  How can I get these to connect
Re: Cannot connect spider edit
by fflbrgst on 2012-01-18 06:08:45.4400
If you check the Effects sections of these boards, you will see this is not an uncommon problem.
What OS are you running - PC or Mac?  Make sure the USB cable is connected direct to the computer and not a USB hub and that you have disconnected any other USB devices.  Disable any virus or firewall software.
I could not get Monkey to recognize the FBV running Vista, but when I did it with an XP computer, I had no problem!
Spider Edit recognizes the FBV in Vista with no problems at all.
by Line6Don on 2012-01-26 16:46:07.6610
Spider Edit will not recognize the Spider IV amp as being connected if the Spider's flash memory is prior to v2.00. You have to update the amp's flash memory in order for it to be compatible with Spider Edit. Instructions on how to do so are available in our video tutorial at the link below:
http://line6.com/community/docs/DOC-2081">http://line6.com/community/docs/DOC-2081">http://line6.com/community/docs/DOC-2081
RE: Cannot connect spider edit
by Line6Don on 2012-02-01 10:33:37.4870
I have marked the answer that is correct for your question, please help out the community by marking other suggestions that were helpful to you as "Helpful Answer".
If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
http://line6.com/support/community/support/
For more information about using the Online Technical Support System please review our FAQ at the link below:
http://line6.com/support/docs/DOC-1451
Thanks!
by fflbrgst on 2012-02-01 12:24:35.2790
Don - that won't work if Monkey does not recognize the devices as tbamorgan said.
