Main :: POD X3
POD X3 Live BLUE SCREEN OF DEATH!!!!
by robinfr93 on 2012-01-22 08:38:03
Hello there,
I've been using my X3 Live for quite some time now. And recently on getting familiar with  some of the recording software like fl studio and Cubase I thought of doing some recording work.
I've got two issues first one is the critical one,i.e,Blue Screen of Death!!
There's no particular timing of it,i.e, it comes in at random after almost any sec,min or hour I connect my unit to the PC via USB.
My second Problem is..
On trying to monitor my sounds in FL studio or Cubase(both reacting the same way) I get a minor latency in the output.Its so light that it comes in soon as I play a note and thus gives it an echo kinda sound which is really irritating.
I've tried reducing the latency through the asio panel of the X3 but no matter what I do, the latency on FL Studio remains with a buffer of 512(12ms).
I know I might not have been able to explain myself clearly but any help will be appreciated.
Looking forward to get a reply.
Robin Francis
Re: POD X3 Live BLUE SCREEN OF DEATH!!!!
by robinfr93 on 2012-01-22 09:17:58
BTW
I used 'WHO CRASHED' to find out the reason for the BSOD and it came out witht the following information.
System Information (local)
computer name: ROBIN-PC
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM)2 Quad  CPU   Q8200  @ 2.33GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 3200593920 total
VM: 2147352576, free: 1929646080
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sun 1/22/2012 3:53:41 PM GMT  your computer crashed
crash dump file: C:\Windows\Minidump\012212-24398-01.dmp
This was probably caused by the following module: l6podx3lv.sys  (L6PODX3LV+0x10175)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFFFFFADA10175, 0xFFFFFFFFB2D93C50, 0xFFFFFFFFB2D93830)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\drivers\l6podx3lv.sys
product: GuitarPort
company: Line 6
description: GuitarPort WDM Audio Device Driver
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: l6podx3lv.sys (GuitarPort WDM Audio Device Driver, Line 6).
Google query: l6podx3lv.sys Line 6 SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
On Sun 1/22/2012 2:19:49 PM GMT  your computer crashed
crash dump file: C:\Windows\Minidump\012212-31871-01.dmp
This was probably caused by the following module: l6podx3lv.sys  (L6PODX3LV+0x1A4C)
Bugcheck code: 0xC5 (0x59F2C181, 0x2, 0x1, 0xFFFFFFFF83134067)
Error: DRIVER_CORRUPTED_EXPOOL
product: GuitarPort
company: Line 6
Bug check description: This indicates that the system attempted to access invalid memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
Google query: l6podx3lv.sys Line 6 DRIVER_CORRUPTED_EXPOOL
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Please reply soon.
Robin Francis
by robinfr93 on 2012-01-22 11:57:16
And one last thing.
The driver version - 4.2.5.1
USB firmware - 1.02
Flash Memory - 2.0
Basic Sytem Information
  • OS Name    Microsoft® Windows 7 Eternity™ 2009
  • Version    6.1.7600 Build 7600
  • Other OS Description     Not Available
  • OS Manufacturer    Microsoft Corporation
  • System Name    ROBIN-PC
  • System Manufacturer    INTEL_
  • System Model    DG43NB
  • System Type    X86-based PC
  • Processor    Intel(R) Core(TM)2 Quad  CPU   Q8200  @ 2.33GHz, 2331 Mhz, 4 Core(s), 4 Logical Processor(s)
  • BIOS Version/Date    Intel Corp. NBG4310H.86A.0054.2008.0813.1914, 8/13/2008
  • SMBIOS Version    2.4
  • Windows Directory    C:\Windows
  • System Directory    C:\Windows\system32
  • Boot Device    \Device\HarddiskVolume1
  • Locale    United States
  • Hardware Abstraction Layer    Version = "6.1.7600.16385"
  • User Name    Robin-PC\Rob
  • Time Zone    India Standard Time
  • Installed Physical Memory (RAM)    3.00 GB
  • Total Physical Memory    2.98 GB
  • Available Physical Memory    1.52 GB
  • Total Virtual Memory    5.96 GB
  • Available Virtual Memory    4.25 GB
  • Page File Space    2.98 GB
  • Page File    C:\pagefile.sys
    Hardware Resources
  1. Conflict/Sharing
  • I/O Port 0x00000000-0x0000000F    Direct memory access controller
  • I/O Port 0x00000000-0x0000000F    PCI bus
  • I/O Port 0x000003C0-0x000003DF    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21
  • I/O Port 0x000003C0-0x000003DF    NVIDIA GeForce 9800 GT
  • IRQ 23    LSI 1394 OHCI Compliant Host Controller
  • IRQ 23    Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
  • IRQ 23    Intel(R) ICH10 Family USB Universal Host Controller - 3A34
  • I/O Port 0x0000E000-0x0000EFFF    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21
  • I/O Port 0x0000E000-0x0000EFFF    NVIDIA GeForce 9800 GT
  • IRQ 16    Intel(R) Management Engine Interface
  • IRQ 16    Intel(R) ICH10 Family USB Universal Host Controller - 3A37
  • IRQ 16    NVIDIA GeForce 9800 GT
  • IRQ 18    Intel(R) ICH10 Family USB Universal Host Controller - 3A36
  • IRQ 18    Intel(R) ICH10 Family USB Universal Host Controller - 3A39
  • IRQ 18    Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
  • Memory Address 0xC0000000-0xD30FFFFF    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21
  • Memory Address 0xC0000000-0xD30FFFFF    NVIDIA GeForce 9800 GT
  • Memory Address 0xA0000-0xBFFFF    PCI bus
  • Memory Address 0xA0000-0xBFFFF    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21
  • Memory Address 0xA0000-0xBFFFF    NVIDIA GeForce 9800 GT
  • IRQ 19    Standard Dual Channel PCI IDE Controller
  • IRQ 19    Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20
  • IRQ 19    Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26
  • IRQ 19    Intel(R) ICH10 Family USB Universal Host Controller - 3A35
  • I/O Port 0x000003B0-0x000003BB    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21
  • I/O Port 0x000003B0-0x000003BB    NVIDIA GeForce 9800 GT
  • Memory Address 0xD3100000-0xD3100FFF    LSI 1394 OHCI Compliant Host Controller
  • Memory Address 0xD3100000-0xD3100FFF    Intel(R) 82801 PCI Bridge - 244E
  • I/O Port 0x00001180-0x0000119F    System board
  • I/O Port 0x00001180-0x0000119F    Intel(R) ICH10 Family SMBus Controller - 3A30
  • I/O Port 0x0000D000-0x0000DFFF    Intel(R) ICH10 Family PCI Express Root Port 4 - 3A46
  • I/O Port 0x0000D000-0x0000DFFF    Standard Dual Channel PCI IDE Controller
2.DMA
Channel 4    Direct memory access controller    OK
3.I/O
0x00000000-0x0000000F    Direct memory access controller    OK
0x00000000-0x0000000F    PCI bus    OK
0x00000010-0x0000001F    Motherboard resources    OK
0x00000020-0x00000021    Programmable interrupt controller    OK
0x00000022-0x0000003F    Motherboard resources    OK
0x00000040-0x00000043    System timer    OK
0x00000044-0x0000005F    Motherboard resources    OK
0x00000060-0x00000060    Standard PS/2 Keyboard    OK
0x00000061-0x00000061    System speaker    OK
0x00000062-0x00000063    Motherboard resources    OK
0x00000064-0x00000064    Standard PS/2 Keyboard    OK
0x00000065-0x0000006F    Motherboard resources    OK
0x00000070-0x00000071    System CMOS/real time clock    OK
0x00000072-0x0000007F    Motherboard resources    OK
0x00000080-0x00000080    Motherboard resources    OK
0x00000081-0x00000083    Direct memory access controller    OK
0x00000084-0x00000086    Motherboard resources    OK
0x00000087-0x00000087    Direct memory access controller    OK
0x00000088-0x00000088    Motherboard resources    OK
0x00000089-0x0000008B    Direct memory access controller    OK
0x0000008C-0x0000008E    Motherboard resources    OK
0x0000008F-0x0000008F    Direct memory access controller    OK
0x00000090-0x0000009F    Motherboard resources    OK
0x000000A0-0x000000A1    Programmable interrupt controller    OK
0x000000A2-0x000000BF    Motherboard resources    OK
0x000000C0-0x000000DF    Direct memory access controller    OK
0x000000E0-0x000000EF    Motherboard resources    OK
0x000000F0-0x000000FF    Numeric data processor    OK
0x000003B0-0x000003BB    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21    OK
0x000003B0-0x000003BB    NVIDIA GeForce 9800 GT    OK
0x000003C0-0x000003DF    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21    OK
0x000003C0-0x000003DF    NVIDIA GeForce 9800 GT    OK
0x000003F8-0x000003FF    Communications Port (COM1)    OK
0x00000400-0x0000047F    System board    OK
0x000004D0-0x000004D1    Motherboard resources    OK
0x00000500-0x0000053F    System board    OK
0x00000540-0x0000057F    Motherboard resources    OK
0x00000D00-0x0000FFFF    PCI bus    OK
0x00001180-0x0000119F    System board    OK
0x00001180-0x0000119F    Intel(R) ICH10 Family SMBus Controller - 3A30    OK
0x0000D000-0x0000DFFF    Intel(R) ICH10 Family PCI Express Root Port 4 - 3A46    OK
0x0000D000-0x0000DFFF    Standard Dual Channel PCI IDE Controller    OK
0x0000D010-0x0000D013    Standard Dual Channel PCI IDE Controller    OK
0x0000D020-0x0000D027    Standard Dual Channel PCI IDE Controller    OK
0x0000D030-0x0000D033    Standard Dual Channel PCI IDE Controller    OK
0x0000D040-0x0000D047    Standard Dual Channel PCI IDE Controller    OK
0x0000E000-0x0000EFFF    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21    OK
0x0000E000-0x0000EFFF    NVIDIA GeForce 9800 GT    OK
0x0000F000-0x0000F01F    Intel(R) ICH10 Family USB Universal Host Controller - 3A36    OK
0x0000F020-0x0000F03F    Intel(R) ICH10 Family USB Universal Host Controller - 3A35    OK
0x0000F040-0x0000F05F    Intel(R) ICH10 Family USB Universal Host Controller - 3A34    OK
0x0000F060-0x0000F07F    Intel(R) ICH10 Family USB Universal Host Controller - 3A39    OK
0x0000F080-0x0000F09F    Intel(R) ICH10 Family USB Universal Host Controller - 3A38    OK
0x0000F0A0-0x0000F0BF    Intel(R) ICH10 Family USB Universal Host Controller - 3A37    OK
0x0000F0E0-0x0000F0EF    Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26    OK
0x0000F0F0-0x0000F0FF    Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26    OK
0x0000F100-0x0000F103    Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26    OK
0x0000F110-0x0000F117    Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26    OK
0x0000F120-0x0000F123    Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26    OK
0x0000F130-0x0000F137    Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26    OK
0x0000F140-0x0000F14F    Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20    OK
0x0000F150-0x0000F15F    Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20    OK
0x0000F160-0x0000F163    Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20    OK
0x0000F170-0x0000F177    Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20    OK
0x0000F180-0x0000F183    Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20    OK
0x0000F190-0x0000F197    Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20    OK
    4.IRQs
IRQ 0    System timer    OK
IRQ 1    Standard PS/2 Keyboard    OK
IRQ 3    Intel(R) ICH10 Family SMBus Controller - 3A30    OK
IRQ 4    Communications Port (COM1)    OK
IRQ 8    System CMOS/real time clock    OK
IRQ 12    Microsoft PS/2 Mouse    OK
IRQ 13    Numeric data processor    OK
IRQ 16    Intel(R) Management Engine Interface    OK
IRQ 16    Intel(R) ICH10 Family USB Universal Host Controller - 3A37    OK
IRQ 16    NVIDIA GeForce 9800 GT    OK
IRQ 18    Intel(R) ICH10 Family USB Universal Host Controller - 3A36    OK
IRQ 18    Intel(R) ICH10 Family USB Universal Host Controller - 3A39    OK
IRQ 18    Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C    OK
IRQ 19    Standard Dual Channel PCI IDE Controller    OK
IRQ 19    Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20    OK
IRQ 19    Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26    OK
IRQ 19    Intel(R) ICH10 Family USB Universal Host Controller - 3A35    OK
IRQ 21    Intel(R) ICH10 Family USB Universal Host Controller - 3A38    OK
IRQ 22    High Definition Audio Controller    OK
IRQ 23    LSI 1394 OHCI Compliant Host Controller    OK
IRQ 23    Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A    OK
IRQ 23    Intel(R) ICH10 Family USB Universal Host Controller - 3A34    OK
IRQ 81    Microsoft ACPI-Compliant System    OK
IRQ 82    Microsoft ACPI-Compliant System    OK
IRQ 83    Microsoft ACPI-Compliant System    OK
IRQ 84    Microsoft ACPI-Compliant System    OK
IRQ 85    Microsoft ACPI-Compliant System    OK
IRQ 86    Microsoft ACPI-Compliant System    OK
IRQ 87    Microsoft ACPI-Compliant System    OK
IRQ 88    Microsoft ACPI-Compliant System    OK
IRQ 89    Microsoft ACPI-Compliant System    OK
IRQ 90    Microsoft ACPI-Compliant System    OK
IRQ 91    Microsoft ACPI-Compliant System    OK
IRQ 92    Microsoft ACPI-Compliant System    OK
IRQ 93    Microsoft ACPI-Compliant System    OK
IRQ 94    Microsoft ACPI-Compliant System    OK
IRQ 95    Microsoft ACPI-Compliant System    OK
IRQ 96    Microsoft ACPI-Compliant System    OK
IRQ 97    Microsoft ACPI-Compliant System    OK
IRQ 98    Microsoft ACPI-Compliant System    OK
IRQ 99    Microsoft ACPI-Compliant System    OK
IRQ 100    Microsoft ACPI-Compliant System    OK
IRQ 101    Microsoft ACPI-Compliant System    OK
IRQ 102    Microsoft ACPI-Compliant System    OK
IRQ 103    Microsoft ACPI-Compliant System    OK
IRQ 104    Microsoft ACPI-Compliant System    OK
IRQ 105    Microsoft ACPI-Compliant System    OK
IRQ 106    Microsoft ACPI-Compliant System    OK
IRQ 107    Microsoft ACPI-Compliant System    OK
IRQ 108    Microsoft ACPI-Compliant System    OK
IRQ 109    Microsoft ACPI-Compliant System    OK
IRQ 110    Microsoft ACPI-Compliant System    OK
IRQ 111    Microsoft ACPI-Compliant System    OK
IRQ 112    Microsoft ACPI-Compliant System    OK
IRQ 113    Microsoft ACPI-Compliant System    OK
IRQ 114    Microsoft ACPI-Compliant System    OK
IRQ 115    Microsoft ACPI-Compliant System    OK
IRQ 116    Microsoft ACPI-Compliant System    OK
IRQ 117    Microsoft ACPI-Compliant System    OK
IRQ 118    Microsoft ACPI-Compliant System    OK
IRQ 119    Microsoft ACPI-Compliant System    OK
IRQ 120    Microsoft ACPI-Compliant System    OK
IRQ 121    Microsoft ACPI-Compliant System    OK
IRQ 122    Microsoft ACPI-Compliant System    OK
IRQ 123    Microsoft ACPI-Compliant System    OK
IRQ 124    Microsoft ACPI-Compliant System    OK
IRQ 125    Microsoft ACPI-Compliant System    OK
IRQ 126    Microsoft ACPI-Compliant System    OK
IRQ 127    Microsoft ACPI-Compliant System    OK
IRQ 128    Microsoft ACPI-Compliant System    OK
IRQ 129    Microsoft ACPI-Compliant System    OK
IRQ 130    Microsoft ACPI-Compliant System    OK
IRQ 131    Microsoft ACPI-Compliant System    OK
IRQ 132    Microsoft ACPI-Compliant System    OK
IRQ 133    Microsoft ACPI-Compliant System    OK
IRQ 134    Microsoft ACPI-Compliant System    OK
IRQ 135    Microsoft ACPI-Compliant System    OK
IRQ 136    Microsoft ACPI-Compliant System    OK
IRQ 137    Microsoft ACPI-Compliant System    OK
IRQ 138    Microsoft ACPI-Compliant System    OK
IRQ 139    Microsoft ACPI-Compliant System    OK
IRQ 140    Microsoft ACPI-Compliant System    OK
IRQ 141    Microsoft ACPI-Compliant System    OK
IRQ 142    Microsoft ACPI-Compliant System    OK
IRQ 143    Microsoft ACPI-Compliant System    OK
IRQ 144    Microsoft ACPI-Compliant System    OK
IRQ 145    Microsoft ACPI-Compliant System    OK
IRQ 146    Microsoft ACPI-Compliant System    OK
IRQ 147    Microsoft ACPI-Compliant System    OK
IRQ 148    Microsoft ACPI-Compliant System    OK
IRQ 149    Microsoft ACPI-Compliant System    OK
IRQ 150    Microsoft ACPI-Compliant System    OK
IRQ 151    Microsoft ACPI-Compliant System    OK
IRQ 152    Microsoft ACPI-Compliant System    OK
IRQ 153    Microsoft ACPI-Compliant System    OK
IRQ 154    Microsoft ACPI-Compliant System    OK
IRQ 155    Microsoft ACPI-Compliant System    OK
IRQ 156    Microsoft ACPI-Compliant System    OK
IRQ 157    Microsoft ACPI-Compliant System    OK
IRQ 158    Microsoft ACPI-Compliant System    OK
IRQ 159    Microsoft ACPI-Compliant System    OK
IRQ 160    Microsoft ACPI-Compliant System    OK
IRQ 161    Microsoft ACPI-Compliant System    OK
IRQ 162    Microsoft ACPI-Compliant System    OK
IRQ 163    Microsoft ACPI-Compliant System    OK
IRQ 164    Microsoft ACPI-Compliant System    OK
IRQ 165    Microsoft ACPI-Compliant System    OK
IRQ 166    Microsoft ACPI-Compliant System    OK
IRQ 167    Microsoft ACPI-Compliant System    OK
IRQ 168    Microsoft ACPI-Compliant System    OK
IRQ 169    Microsoft ACPI-Compliant System    OK
IRQ 170    Microsoft ACPI-Compliant System    OK
IRQ 171    Microsoft ACPI-Compliant System    OK
IRQ 172    Microsoft ACPI-Compliant System    OK
IRQ 173    Microsoft ACPI-Compliant System    OK
IRQ 174    Microsoft ACPI-Compliant System    OK
IRQ 175    Microsoft ACPI-Compliant System    OK
IRQ 176    Microsoft ACPI-Compliant System    OK
IRQ 177    Microsoft ACPI-Compliant System    OK
IRQ 178    Microsoft ACPI-Compliant System    OK
IRQ 179    Microsoft ACPI-Compliant System    OK
IRQ 180    Microsoft ACPI-Compliant System    OK
IRQ 181    Microsoft ACPI-Compliant System    OK
IRQ 182    Microsoft ACPI-Compliant System    OK
IRQ 183    Microsoft ACPI-Compliant System    OK
IRQ 184    Microsoft ACPI-Compliant System    OK
IRQ 185    Microsoft ACPI-Compliant System    OK
IRQ 186    Microsoft ACPI-Compliant System    OK
IRQ 187    Microsoft ACPI-Compliant System    OK
IRQ 188    Microsoft ACPI-Compliant System    OK
IRQ 189    Microsoft ACPI-Compliant System    OK
IRQ 190    Microsoft ACPI-Compliant System    OK
IRQ 4294967291    Intel(R) 82567V-2 Gigabit Network Connection    OK
IRQ 4294967292    Intel(R) ICH10 Family PCI Express Root Port 4 - 3A46    OK
IRQ 4294967293    Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40    OK
IRQ 4294967294    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21    OK
5.Memory
0xD3200000-0xD32FFFFF    Intel(R) ICH10 Family PCI Express Root Port 4 - 3A46    OK
0xD3100000-0xD3100FFF    LSI 1394 OHCI Compliant Host Controller    OK
0xD3100000-0xD3100FFF    Intel(R) 82801 PCI Bridge - 244E    OK
0xD3325900-0xD332590F    Intel(R) Management Engine Interface    OK
0xFED00000-0xFED003FF    High precision event timer    OK
0xD3300000-0xD331FFFF    Intel(R) 82567V-2 Gigabit Network Connection    OK
0xD3324000-0xD3324FFF    Intel(R) 82567V-2 Gigabit Network Connection    OK
0xBF000000-0xFFFFFFFF    PCI bus    OK
0xD3325000-0xD33253FF    Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A    OK
0xFED1C000-0xFED1FFFF    System board    OK
0xFEC00000-0xFECFFFFF    System board    OK
0xFEE00000-0xFEE0FFFF    System board    OK
0xFF000000-0xFFFFFFFF    System board    OK
0xFED14000-0xFED19FFF    System board    OK
0xE0000000-0xEFFFFFFF    System board    OK
0xD3325800-0xD33258FF    Intel(R) ICH10 Family SMBus Controller - 3A30    OK
0xD3325400-0xD33257FF    Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C    OK
0xFFE00000-0xFFFFFFFF    Motherboard resources    OK
0xFED30000-0xFED3FFFF    Motherboard resources    OK
0xFED08000-0xFED08FFF    Motherboard resources    OK
0xC0000000-0xD30FFFFF    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21    OK
0xC0000000-0xD30FFFFF    NVIDIA GeForce 9800 GT    OK
0xD3320000-0xD3323FFF    High Definition Audio Controller    OK
0xD2000000-0xD2FFFFFF    NVIDIA GeForce 9800 GT    OK
0xD0000000-0xD1FFFFFF    NVIDIA GeForce 9800 GT    OK
0xA0000-0xBFFFF    PCI bus    OK
0xA0000-0xBFFFF    Intel(R) 4 Series Chipset PCI Express Root Port - 2E21    OK
0xA0000-0xBFFFF    NVIDIA GeForce 9800 GT    OK
6.Sound Device
Name    Realtek High Definition Audio
Manufacturer    Realtek
Status    OK
PNP Device ID    HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_80860023&REV_1002\4&1877A340&0&0201
Driver    c:\windows\system32\drivers\rtkvhda.sys (6.0.1.6201, 3.04 MB (3,190,248 bytes), 8/1/2011 8:11 PM)
And one last thing.
USB firmware - 1.02
Flash Memory - 2.0
    Hardware Resources
  1. Conflict/Sharing
2.DMA
3.I/O
    4.IRQs
5.Memory
6.Sound Device
Status    OK
by johnpicton on 2012-01-23 01:52:27
I am not going to say that this is the problem (and I am prepared to be corrected on this one) but when I looked it up Windows 7 Eternity is a hacked version of Windows7, not supported by Microsoft and has all updating turned off. It is entirely possible that the BSOD you are getting is because of some non standard Windows hacks that were put in to circumvent the the OS.
I found this when I did a search http://www.howtogeek.com/forum/topic/windows-7-eternity
I">http://www.howtogeek.com/forum/topic/windows-7-eternity">http://www.howtogeek.com/forum/topic/windows-7-eternity
Isincerely hope that I am wrong and that somebody will chip in with a solution for you.
Good Luck
John
by robinfr93 on 2012-01-23 04:49:35
Thanx for the reply John.I really appreciate it.
But after reading your post I tried it at one of my friends PC running Windows 7 Ultimate.
And the same problem occurred but this time BSOD appeared as soon as we installed the drivers,restarted the machine and plugged in the cable.
Robin Francis
by johnpicton on 2012-01-23 05:43:50
From your point of view I am pleased that the problem was replicated - means it isn't your copy of Windows 7.
I am currently using the HD500 on Windows 7 Ultimate and also Windows 7 Pro and haven't experienced the BSOD at all (I got it a lot with my X3 - but not with the HD).
This was the reason why I bought the HD - I know that doesn't help you with your X3 problems. In the end for me it was wort updating to an HD, costly I know. I know for a fact that part of my problem was that I have an older X3 that experiences the USB audio drop out (based on the other symptoms I was having and the SN of the unit). One of these days I will send the X3 in to get the free repair done. Fact is the problems didnt manifest themselves until I upgraded to a new computer running Windows 7.
As I said, hopefully somebody else who knows a bit more than me can chip in on this.
Best of luck sorting it.
Cheers
John
by robinfr93 on 2012-01-24 04:03:35
Hey John,
After reading your post.I got an HD 500 from one of my friend to see if the problem persists or not and you were right.
Its not there!!
And I can't really upgrade to HD as I don't have that much amount of dough at the moment.
But I really wanna get rid of this issue as using the VST plugins in these softwares I'm able to make far too sweet tones.
Damn you!! line 6 guys.
I know you have stopped X3's production but this is no way to treat your consumer!!So please people there at the line 6!!
HELP ME OUT!!
Please guys can you please develop a new driver that solves this problem.
Please??
Robin Francis
by robinfr93 on 2012-01-25 23:03:10
hey there,
Won't anyone from line 6 try to help me out. PLEASE????
Robin
by johnpicton on 2012-01-26 03:34:40
Hi again Robin
no conclusive answer, sorry. But the X3L (actually most line6 kit) is very picky about the USB side of things. I am absolutely sure that you have made sure that you aren't using a hub (even an internal one). I have heard it said that purchasing a new internal USB2 Card can resolve issues like this. Not as expensive as updating to an HD, but of course no guarantee that it will work.
It is also possible that your X3 is suffering from the USB audio drop out problem, which if it is the case could (in my opinion) be tripping up your system when it happens and could be causing the BSOD.
If it is down to the USB drop out then there is a free lifetime fix for this offered by Line6. You can tell by the serial if you might have the problem. All units that have serial number 21X3L1S591....... or later have had the fix already applied. If your serial is lower then it is possible that you have the problem Have a look at the following:-
http://line6.com/support/message/138160#138160
If">http://line6.com/support/message/138160#138160">http://line6.com/support/message/138160#138160
Ifyou do need to have the fix done contact your service center and ask them to look up Line6 technical bulletin #52.
This could also be worth a look - it is a document on optimizing the USB on your system for Line6 stuff
http://line6.com/support/docs/DOC-4282
As">http://line6.com/support/docs/DOC-4282">http://line6.com/support/docs/DOC-4282
AsI said these are only suggestions.
Good Luck
by robinfr93 on 2012-01-29 03:18:21
Hey
Oh I can't thank you enough for this John.
The posts were really helpful and i contacted my dealer about this and Ill be shipping in my POD soon.
Once again thanks a ton for this, Ill keep you updated.
You've been great help since the beginning my Friend.
Thanks a ton.
Lets just hope this fixes everything.
Robin Francis
by Line6Don on 2012-02-08 15:52:32
If the POD X3 is assigned as the system's sound card, unplugging it from the USB or powering it off can cause the computer to blue screen. If the system is blue screening without you unplugging or turning off the POD X3, it is possible that there is an intermittent USB connection, and when the connection drops it cause the system to crash.
I would suggest that you have the POD X3 Live looked at by a Line 6 Service Center. To find one in your area you can use the finder at the link below:
http://line6.com/service_centers/
Your">http://line6.com/service_centers/">http://line6.com/service_centers/
Yourdealer should also be able to help you located a repair center for you as well.
by Line6david on 2012-02-09 17:18:06
Hello,
It has been at least 72 hours since we've heard from you. since there was no closure to your issue, we’ll open a ticket for you to post to if you have trouble down the line.
Q: What is a support ticket?
A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link if a Line 6 support representative determines that a ticket is necessary to troubleshoot your issue. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support.
Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host.
http://line6.com/account/tickets/view/
by nbmaltais on 2012-03-07 20:02:58
I have both problems described in this thread ( occasionnal blue screen of death and audi drop out). Did you manage to solve your problem?
Nic
by mikebryant on 2013-01-14 01:43:29
I am gutted. I have the same problem and didn't know about it.
I just received a new i7 Scan Computer this weekend: http://3xs.scan.co.uk/ShowSystem.asp?SystemID=1465
">http://3xs.scan.co.uk/ShowSystem.asp?SystemID=1465">http://3xs.scan.co.uk/ShowSystem.asp?SystemID=1465
I installed a new copy of Cubase 7 within the first three days of use, I had about ten crashes.
My system even became buggy and had problems shutting down.
What a drag! A new computer messed up by Pod X3L!!  Argggh!!!
I didn't know what the problem was until I read this thread. For what it's worth, I've instigated a Ticket with Line 6.
But will Line6 actually do anything about it?
I hate the thought of having to purchase another product (HD) just to solve the problem.
But I also use Reason 6.5 a lot and enjoy the Line6 amps available in that product and the ability to record the "Dry" guitar.
All drivers are up to date on both the X3L and Windows and Cubase. I understand that Line6 provides some sort of support for this problem?
Any solutions / suggestions would be appreciated re: using Pod X3L with Cubase.
by curtisline6 on 2013-03-11 15:42:14
I have a similar problem but I don't have to have anything open: Pro Tools, Cubase or anything else. It's only sometimes and only on POD startup and doesn't matter whether I have power or USB connected first.
On my first complaint of this I was told it wasn't heard of and would be assumed to be a repair issue. I actually thought it was loading the USB line too heavily but found the same problem connecting to powered USB strip.
The only solution I found was starting up the computer with USB connected and POD already powered up- annoying at best and I don't want to leave my POD on all the time or restart my computer every time I want to use the POD.
It's too bad. I thought it was otherwise a great piece of equipment. I hope if anyone finds a solution they will post. I will do the same.
Very interesting. I have to modify my last statement. While investigating I checked Device Manager POD500, and found some big yellow question marks, so I attempted to update the driver, as it asked. Windows found the driver and attempted to update it, about three seconds into it...the familiar blue screen, with me doing nothing else. Maybe I should've disconnected the hardware first?
