Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
cracking poping noise using Pod xt with MacBook Pro Lion
by pollina on 2012-02-04 14:33:59.6110
Hello, I recently buy a MacBook Pro with Lion OSX, install the Line6 software and connect my Pod XT with an USB cable, and when I try to use it all the audio sounds poping and cracking, not only with Logic but also with iTunes and all the audio comming from my computer... I´ve tryied to low and high the latency, looking on the Audio and Midi Setup from my computer and nothing... After a while sometimes it starts to function properly but every time I connect it I get the same problem and I can´t work...   I know it´s not my Pod xt because I have tryied with my boyfriend Pod xt and I get the same issue, also I have and old Powerbook G4 and never have a problem like this and if I use it in Solo mode (without the computer) sounds fine... Any sugestions,  please some help????
Re: cracking poping noise using Pod xt with MacBook Pro Lion
by laplayantonio on 2012-02-15 02:40:42.2270
hello
please try reflashing your XT: http://line6.com/support/docs/DOC-3827
if this doesn't cure it, please contact your nearest Line6 Service Center: http://line6.com/service_centers/
line6antonio
by pollina on 2012-06-10 05:12:36.6820
Hello, thanks for the advice, already tryried but it didn´t solve it. However after tryied many thinks I just find a way to make it work, so I will post it here to help others with this problem...
You must turn up the POD xt (with the USB connected but the Mac turned off), wait a couple of minutes and then turn on the Mac. This solve it for me, so now I can work properly...
