Main :: DT50/DT25
DT25 - Very low gain on voicing 2 (Full Volume)
by Titi1506 on 2012-02-15 16:50:52.3960
When I use my DT25 in LVM with voicing II, I can get a fair amount of gain for my lead tones. If I switch to full volume with the same settings, my sound suddenly becomes clean and, whatever I do, I can't get more than a very light crunch tone even with the master cranked up, drive to the max and channel volume to the max…
Does anybody have the same issue?
Thanks in advance
Bertrand
Re: DT25 - Very low gain on voicing 2 (Full Volume)
by strathead_1 on 2012-02-16 10:56:37.3810
I have noticed the same thing on my DT25 combo.
I put it down to my stratocaster (although it does have Fender Hot Noiseless in it).
I need an overdrive pedal to get what I consider a nice Marshall sound.
What guitar do you use Bertrand?
Regards,
Strathead
by Titi1506 on 2012-02-16 11:44:10.8930
Hi Strathead,
I have many Les Pauls but all with Throbak P.A.F. style pickups (not really hot).
An overdrive pedal would be a solution but I'd really like to be able to get a nice Marshall lead tone without it (not really hi gain JCM style but at least JTM45 or JMP).
I've choosen the DT25 in order to have a small transportable tube gig anp… I also have a POD HD500 to add a little bit gain but I'm more a Guitar/Amp guy. Of course I could use the voicing IV but I find it too modern…
Normaly, in a vintage configuration like the voing II the distortion should come from the power section but it doesn't seem to work with the HD25…
by sopachrga on 2012-02-16 19:09:27.3990
Have you tried switching the Pentode/triode mode?
The triode mode might offer a bit more gain.
by Titi1506 on 2012-02-16 23:06:23.7150
Hi Sopachrga,
I've tried the triode mode as well… But it stills having less gain than my JTM45 at 2 o'clock…
by sopachrga on 2012-02-17 02:17:29.2650
I just tried with my DT50 head. I get pretty much the same gain in standard mode as I do in LVM.
I guess the DT50 and DT25 have different power amp valves, so I'm not sure how useful that test is though.
by Titi1506 on 2012-02-17 02:21:47.0940
Could you maybe post some samples… I would appreciate it a lot! I have to find out if my amp has a problem or if it's the wrong choice for my needs.
Kind regards,
Bertrand
by sopachrga on 2012-02-17 03:06:10.8930
I can try tomorrow. It's currently 12:05AM here in New Zealand. So my neighbours probably wouldn't be too impressed.
by Titi1506 on 2012-02-17 03:11:23.4560
LOL!
Thanks a lot! it's very kind from you!
by sopachrga on 2012-02-17 15:46:11.6260
Check this here: http://soundcloud.com/mindless-and-mesmerized/dt-mode-2-flat-eq">http://soundcloud.com/mindless-and-mesmerized/dt-mode-2-flat-eq">http://soundcloud.com/mindless-and-mesmerized/dt-mode-2-flat-eq
It's just a few seconds of a couple of chords in both Full volume mode and LVM. (Full vol first, LVM second)
Ignore the playing it is just done so you could hear the gain levels.
The settings were the same in both modes.
They both sounded about the same amount of gain, alothough the LVM has far less mids and bottom end.
I used a 1981 Les Paul Custom.
Settings:
Drive = 3 o'clock
Bass = 12 o'clock
Mid = 2 o'clock
Treble = 1 o'clock
Presence = 2 o'clock
Reverb = only just above zero
Chan Volume = FULL
Master volume = 4 o'clock
I was using a Marshall power brake to keep the volume down.
Cheers
by Titi1506 on 2012-02-20 02:46:43.9690
Thanks a lot!
You seems to get the same amount of gain in Full Volume Mode and LVM… It's really not the case for me…
I start to believe that my amp could have a problem! I wish somebody could to the same test with a DT25.
by juliancarosi on 2013-04-09 16:29:41.6820
I had exactly the same problem. I’ve got an American Strat and a Tele (with a bridge humbucker) and just could not get the dirty sound that you are supposed to get on the Line 6 amps.
See my thread here: http://uk.line6.com/support/thread/148053
Now that my DT25 has been fixed, I can even get a dirty sound on the clean amp settings by just turning up the Drive knob.
by thegwoe on 2013-04-09 19:59:21.4670
Alas my DT50 has the problem where voicing 1 and 3 have completely dissapeared while 2 & 4 are fine.  Does anyone have a schematic for this amp they could send me?
I live in the wilderness and while I have a great liscensed tech nearby who can fix anything, the freight to the nearest Line6 service center will kill me on costs.  I'm starting to wish I'd never bought this amp....
by adamhartley on 2013-04-15 23:08:11.2200
Master volume on the DT25 needs to be up at least around 12 o'clock to get the natural OD you'd expect from models like the plexi and park. Below about 11 or 10 o'clock I could never get the DT25 sounding like a rocking amp in normal mode. In LVM, there's modelling going on in the power amp section.
A lot to do with how the power amp actually works in normal or low volume mode. Doesn't affect the high gain models as much, but for classic rock tones with switch2, they mimic the amps they are designed on in that they are cleanish sounding at low volume or when guitar's volume pot rolled back. I've tested this a lot at gigs and at home and I'm sure its no amp fault, as much as design.
