Main :: POD HD
Can I use POD HD500 as a MIDI controller and its functions at the same time?
by masarez on 2012-03-07 12:04:40.5770
I just want to connect POD 2.0 in its FX loop and then control it with the HD500 via MIDI. However, I still want to use the HD500's functions i.e. I want to use amp model from POD 2.0 while using the modulations from the HD500. Can I do that?
Re: Can I use POD HD500 as a MIDI controller and its functions at the same time?
by Line6david on 2012-03-15 11:51:00.9320
Theoretically, yes. You should connect your guitar to the POD 2.0 and the L./Mono out of the 2.0 to the FX Return of your amp.
Next connect the HD500 via MIDI and use it to control the amp.
http://line6.com/data/6/0a06434d5f004f286bebc8142/application/pdf/POD%20HD500%20Advanced%20Guide%20-%20English%20%28%20Rev%20B%20%29.pdf">http://line6.com/data/6/0a06434d5f004f286bebc8142/application/pdf/POD%20HD500%20Advanced%20Guide%20-%20English%20%28%20Rev%20B%20%29.pdf">http://line6.com/data/6/0a06434d5f004f286bebc8142/application/pdf/POD%20HD500%20Advanced%20Guide%20-%20English%20%28%20Rev%20B%20%29.pdf
Appendix B
Thanks,
David
by eraker on 2012-03-17 15:52:04.6150
short answer: YES
long answer: I am doing this and I am using the 4 cable method with a Marshall JVM. I am using the pod to change channels and settings on the Marshall. It is really great. The best thing is that it is really easy to program the midi signals to the Marshall.
by Line6david on 2012-03-22 11:55:45.1560
Hello. It has been at least 72 hours since we've heard from you. We're going to assume your question has been answered. If it has been answered, please award points to whoever was helpful and/or answered the question.
In the event your issue has not been resolved, I created a support ticket for you so we can continue to communicate. Please respond to the ticket. Thanks!!
Q: What is a support ticket?
A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link to the ticket when a Line 6 Support Representative responds to it. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support. Also, in your account, click My Account, then click Support Tickets to view the support ticket. Here’s a shortcut: http://line6.com/account/tickets/view/.
Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host, and also that your email account is receiving messages at all.
by jimsreynolds on 2012-03-22 13:31:20.1020
+1
