Main :: Spider Jam
Problem with write to wav file
by ariegitarie on 2012-03-18 12:34:44.3020
how can I convert a jam file to a wav file, because my unit doesn t write it to a wav file, I don t know wy, I have try many times,
how can I fixed this problem ?
Re: Problem with write to wav file
by laplayantonio on 2012-03-19 06:03:07.8360
hello
please read in page 2•3 of 'Spider Jam Advanced Guide (Rev B) - English' how to export recordings as .Wav file : http://line6.com/support/manuals/spiderjam
line6antonio
by darealagentp on 2012-03-20 11:19:54.6390
Make sure your SD Card is under 2GB. Also, if you connect the SD Card to a host computer, there needs to be a folder labeled as: LINE6 on the root of the card device.
When you enter the "Save" options in the Spider Jam, there's an option to: "SAVE REC MIX AS WAV TO CARD". This is the option to save a recording on your Spider Jam into a .wav file within the LINE6 folder of the inserted SD Card. Make sure your SD Card has enough free space on it to write audio data, too!
