Main :: Sonic Port / Mobile In
Recording Vocal
by Loekito on 2012-03-25 09:11:06.3400
Can I record vocal using a mic connected to my POD HD500 to my iPad using Mobile In ?
The routing is: Mic --> POD HD500 XLR in --> POD HD 500 Phones Out --> Mobile In --> iPad
Thanks,
Loekito
Re: Recording Vocal
by silverhead on 2012-03-25 09:20:54.1420
That should work fine. You will need to use a Core Audio compatible recording program on the iPad (e.g., Garageband).
Re: Recording Vocal
by Loekito on 2012-03-25 19:25:10.3400
Hi, thanks for the reply.
So I just need to provide a stereo cable with 1/4in jack, and 1/8in jack on the other side.
How about the level (db) between Phones Out on POD HD500 and Line Input on Mobile In ?
Regards,
Loekito
Re: Recording Vocal
by silverhead on 2012-03-25 20:11:54.2230
The PHONES output level on the Pod HD500 is controlled by the Master Volume level. Start with a relatively low setting but try to increase it as much as you can without overloading the input of your recording program. The Mobile In hardware can certainly handle the input level, and the higher the Master Volume level from the HD500 the better is its signal-to-noise ratio. However, turning it up too high will probably clip the input of your recording program.
