Main :: POD HD
Problem with Roland EV-5
by takitiger on 2012-05-12 00:44:12.6990
Hi there,
I noticed in the forum a lot of people are using the Roland EV5 for a second expression pedal with the POD HD500
I bought the same for the same reason.
But, when I plug it in the indicator light lights up when the jack is halfway and goes out again when I fully plug it in. Gotta be the stereo jack or?
How do I get rid of that problem?
Also, I tried to keep it there (halfway) for a while to see how it's working. It's working backwards. Heel full on and tip zero. Is there any way to fix that or do I have to go and reverse all my mins and maxs of my sounds?
I will only use the Roland as a volume pedal to control ch vol out, as the built in one I will use mostly to control my delay mix
Any help will be appreciated. I'm not THAT good with things like that you see
Re: Problem with Roland EV-5
by takitiger on 2012-05-13 05:05:25.1070
hmmmm, bump?
by takitiger on 2012-05-14 03:04:32.8320
Problem solved
Just replace the stereo jack of the EV5 with a mono one, cut away the "naked" wire (you won't need) and solder the wires on the jack just like you would do on any mono jack.
Works like a charm
For the "backwards" working, just open the pedal, find the pot that the pedal is attached to and replace the 2 edge wires (solder the one to the othr's place)
Done
by Rewolf48 on 2012-05-14 05:38:19.8170
I use an EV-5 and haven't had any problems with it once you realise that the Minimum Volume adjustment knob has to be set to "0" otherwise it does act funny.  Push the plug all the way in and both expression lights should come on.  The Line 6 equivalent doesn't have the "advanced" minimum volume function of the BOSS unit so the HD500 doesn't like it.
The only thing I did was to open up the EV-5 and fold all but a foot of the cable into the body so that it sits neatly on the right of the HD500 without cable everywhere.
by takitiger on 2012-05-14 09:30:22.6300
Thanx a lot man
