Cannot Get KB37 Working With Win7 64 Bit - Error -997
by NOVAkILL on 2012-05-28 17:59:53.6960
The title says it all. I have tried installing my KB37 drivers using both GearBox and POD Farm but I continue to get the same error message when my VST host application - Synapse Audio Orion - tries to start the ASIO drivers. My other ASIO devices work properly, at this stage it is just the KB37 that is having trouble. I notced an announcement for new drivers but the link gives a 404 error. My computer specs are -
Asus Zenbook UX21
Core i7 CPU
4Gb RAM
Win7 Home Pemium 64bit SP1
I was having other, unrelated problems so I have just freshly wiped the drive and started again, so I really don't have much stuff installed beyond what I need for music. We have a gig in a couple of weeks and I would really like to get the KB37 working before then. I can still use it as a MIDI controller, so we can practice/rehearse OK, but I don't want to have to rely on ASIO4all on stage and we normally use GearBox for vocal effects (POD Farm is still useless for KB37).
Re: Cannot Get KB37 Working With Win7 64 Bit - Error -997
by Triryche on 2012-05-29 07:53:33.0130
Try getting the driver from here
http://line6.com/software/readeula.html?rid=4791">http://line6.com/software/readeula.html?rid=4791">http://line6.com/software/readeula.html?rid=4791
And Monkey from here
http://line6.com/getrelease?rid=4926">http://line6.com/getrelease?rid=4926">http://line6.com/getrelease?rid=4926
by NOVAkILL on 2012-05-30 22:07:10.0970
Thanks for the links but even with the latest drivers I am still getting the same -997 error as before. There is nothing wierd about my configuration, it is just a bog-standard laptop.
by Triryche on 2012-05-31 06:27:46.8470
Did you try different USB ports?
You can open a support ticket to deal with Line6 one  on one.
http://line6.com/support/tickets/add.html">http://line6.com/support/tickets/add.html">http://line6.com/support/tickets/add.html
In the meantime fill out your computer profile if you haven't already.
by NOVAkILL on 2012-06-03 03:44:08.0790
Moving it to the other USB port has solved the problem. It is not a solution that fills me with confidence but it does seem quite robust now. I had it plugged into the USB 3 socket, so maybe there was a problem with that, even though USB 3 is supposed to be backwards-compatible.
