Main :: POD HD
is possible to have a master midi clock with a Pod Hd Pro?
by Parker1976 on 2012-07-05 03:12:43.5750
Re: is possible to have a master midi clock with a Pod Hd Pro?
by mazuwa on 2012-07-05 07:13:43.3480
The POD HD might work as MIDI Slave, e.g. concerning tempo based FX. If you set values as a note (score) value (1/2, 1/4, 1/8, dotted 1/4, ....) instead of fixed time values, it should take the sync. Take care of the GLOBAL / PRESET BPM value.
Please see also manual on chapter 2.10 - 2.11, PAGE 6 MIDI / TEMPO OPTIONS..
Sorry, I first misunderstood:
(The manual on chapter 5.9, PAGE 5, SETUP: DIGITAL OUTPUT SETUP says:
"When connecting to another digital device, it is best to clock the external device to follow POD HD Pro (with POD HD Pro as the "master" device) to maintain proper synchronization - please see your digital device's documentation for its digital clock features."
HD Pro = MASTER; other device = SLAVE.
If the other device cannot be set to SLAVE (follow POD HD Pro), no proper synchronization is guaranteed.)
by ReverendLove on 2012-07-06 04:16:48.7390
He was asking obviously for MIDI not for digital audio synchronization.
On MIDI just give it a try. Switch your DAW or MIDI gear to external MIDI sync, connect with your POD and look what happens.
As for MIDI slave: I have a POD HD 500 and can use it as MIDI-slave. The implementation is a little bit sticky, but it works acceptable.
by Parker1976 on 2012-07-09 02:34:06.9720
Thanks, man.
