Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
Fixing persistent annoying distortion on every setting of a POD 2.0
by scotty1991 on 2012-07-19 05:27:39.0430
I have a POD 2.0 and recently the sound became distorted on every setting, regardless of amp model or effect setting. It's a very unattractive fuzzy sound which appeared to come on very suddenly, as though there had been a change in the hardware of the device.
I have isolated the POD as the source of the problem, the guitars and the amp seem to be working fine.
Is there a solution to this problem?
Thanks in advance for any help offered!!
Re: Fixing persistent annoying distortion on every setting of a POD 2.0
by Triryche on 2012-07-19 08:57:11.7110
Have you tried a factory reset?
(Back up your patches first)
http://line6.com/support/docs/DOC-4499">http://line6.com/support/docs/DOC-4499">http://line6.com/support/docs/DOC-4499
POD/POD 2.0/Bass POD/POD Pro: press and hold the up and down arrow buttons as you power the unit on for ~ 5-7 seconds or until it goes to the preset 1-A
by scotty1991 on 2012-07-23 04:40:51.4350
Sadly that hasn't worked. Any other suggestions?
