Main :: StageSource Speaker Community Support
Internal L3M sample rate
by arstrand on 2012-08-05 00:10:36
I want to use the L3M within a studio that uses 96K sample rates.  As such I have several questions:
Questions
  1. What is the internal DSP sampling rate i.e. 48K, 96K etc?
  2. Can the L3M DSP sample rate be set to 96K or above?
  3. Has Line6 considered adding digital input that allows connection to a DAW digitally so there are no unnecessary analog->digital->analog conversions in the signal chain? (Sorry if I missed this input in the literature)
  4. If current sample rate is 48K has Line6 considered adding 96K and above sample rates?
Thanks in advance.
Allen
Re: Internal L3M sample rate
by dboomer on 2012-08-05 19:52:59
The internal sample rate is fixed at 24 bit / 48 kHz.  It is not user adjustable.  The only way at access the input without analog/digital conversion is to use the Line 6 link (curently only supported by Pod HD's and the StageScape mixer).  I suppose if there was enough demand for a higher sample rate or alternate digital inputs they could show up some day in Line 6 speakrers, but I don't anticipate that in the near future.
