Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
line 6 pod xt
by bryanOconnor13 on 2012-08-17 18:14:31.3260
i have a pod xt, and it has a problem.. the four soft key under the screen wont work.
what should i do?
help me please.
Re: line 6 pod xt
by toneman2121 on 2012-08-17 20:18:30.6930
is it still working? try re- installing software
Re: line 6 pod xt
by bryanOconnor13 on 2012-08-18 07:41:53.5050
yes, it works properply, but the four soft key is not working., but sometimes the 1st button work
re-installing software? how can i do that?
Re: line 6 pod xt
by toneman2121 on 2012-08-18 08:49:06.7510
http://line6.com/support/docs/DOC-3827
Message was edited by: frank biafore
make sure you read all of the doc
Re: line 6 pod xt
by bryanOconnor13 on 2012-08-18 18:59:13.4120
hello sir, i got a problem before because i install in my pod xt is version 1.0x. i downgraded it. and its all my fault
and now i cant upgrade it to the latest version,cos i dont have a usb-midi cable.
what should i do?
if i upgrade it to the latest version? the four button will work?
Re: line 6 pod xt
by TheRealZap on 2012-08-18 19:25:49.6620
you need to get a midi cable.
no idea if that will fix the buttons though... but one way to find out....
you can get cheap midi cables for around 5$ on ebay.... fwiw
Re: line 6 pod xt
by toneman2121 on 2012-08-18 20:22:01.1550
the recommended device is m-audio midisport
Re: line 6 pod xt
by bryanOconnor13 on 2012-08-18 22:42:59.3570
only th m- audio cable can update my pod xt?? what if i use other usb midi cable?
if its updated, then, the button wil work?
Re: line 6 pod xt
by TheRealZap on 2012-08-19 05:49:30.9660
you can use other midi cables... and they can work... but line6 internally tests with the m-audio uno, and so they tend to be most likely to work and therefore recommended.
the only way to know if the buttons will work is to flash it....
you might just call the local music shop and ask them if they can help you with it....
they may be willing to let you use their midi cables etc....
Re: line 6 pod xt
by toneman2121 on 2012-08-19 05:59:27.8840
trans.gifthe recommended midi to usb is m-audio midi sport.
http://www.pssl.com/!FbUmaXn4RY!9!UP5aGoVDQ!/M-Audio-USB-UNO-Multiplatform-USB-Midi-Interface-s?gclid=CInHu_He87ECFUKo4AodkmYAMQ
Re: line 6 pod xt
by bryanOconnor13 on 2012-08-19 20:46:37.9140
ok sir i try to visit the shop, im from philippines
thankyou all
Re: line 6 pod xt
by bryanOconnor13 on 2012-08-19 20:47:08.5870
the only way to know if the buttons will work is to flash it???
