Main :: FBV MkI / MkII Controllers
Help.
by camp-a-lamp on 2012-08-24 09:48:18
I just received my MKII shortboard and I am trying to set it up. I plugged it into my Spider 2 30 amp and the screen just says "FBV SB MKII." I can switch between my main patches but I cannot control the volume. If I press any button other than the A, B, C, or D buttons, it takes me back to the A patch. I have no idea how to fix this. I've tried "re-flashing" with Line 6 Monkey and that didn't help. When I plug it into my computer, it seems like it works as it is supposed to. I can select a patch, use the Stomp, Mod., Delay, and Reverb buttons without changing it back to patch A; and when I use the volume pedal, I can see the number on the screen go from 0-127. Also, the green LED lights up when plugged into my computer, but not the amp. And I've tried using different RJ-45 cables.
I've searched and can't find any thing like this, and I have read the manual.
Re: Help.
by fflbrgst on 2012-08-24 09:53:31
Sorry to tell you that the control you are getting, of selecting the 4 user channels, is all you can control with that amp.  Per the FBV compatibility chart here:  http://line6.com/footcontrollers/compatibility.html the Shortboard is not compatibile with the Spider 4 30 or the Spider 3 30, I would assume the same is true for the Spider 2 30.
Re: Help.
by camp-a-lamp on 2012-08-24 11:55:36
Looks like I'll be getting a newer amp then. I love the spider amp. I've been wanting something louder anyways. Thanks.
