Main :: Vetta
Vetta 2 -How to copy Tones from the Custom Tone site into the amp.
by derekbradburn on 2012-09-05 03:35:03.4040
Hello,
Just bought a Vetta 2 amp and would like to know the procedure for copying Tones from the Custom Tone site into the amp.
I already have a USB to Midi interface.
Thanks,
Derek B.
Re: Vetta 2 -How to copy Tones from the Custom Tone site into the amp.
by DickFoster on 2012-09-06 09:59:06.3930
First of all be sure you are using THE proper USB to Midi adapter not just any USB to Midi adapter.
Time and time again problems have been resolved by using an M-Audio Uno USB/Midi adapter. Be sure you download and install the latest driver for your OS from M-Audio's site.
After that you can use the Line 6 Edit program, (a free download from Line 6) to download and save custom patches between your computer and your Vetta amp.
Here is one link where you can pick up the USB adapter, there are lots of others.
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
by Grinder666 on 2013-01-06 18:12:31.6370
I'm using M-Audio interface and though it finds my vetta head it says cannot connect, all cables look to be in right place, thoughts?
by DickFoster on 2013-01-07 09:18:52.1000
Is the amp working otherwise?
Have you tried swapping the cables around?
Is the M Audio driver current for the computer and OS you're using?
by Grinder666 on 2013-01-07 12:04:56.3510
turns on but no sound
yes cables are correct
will check driver
It also says " vetta is currently bus, please wait for current operation to complete"
installed correct driver and works with my flextone head, guess I'm sunk....
