Main :: DT50/DT25
Assign AMP A to channel A and AMP to channel B
by fdesnoyers on 2012-09-07 12:42:11.4620
Is there a way I can assign AMP model A of HD500 to Channel A of my DT50 and AMP model B (with totally different setup) to Channel B intead of having to use 2 DT50 when switchingfrom 1 model to the other.
This would look like this:
HD500 AMP model A linked to DT50 AMP A, Channel A
HD500 AMP model B linked to DT50 AMP A, Channel B.
As for now, when I switch to HD500 AMP model B, my DT50 is switching to channel B but any modification applied on either one of the devices are not replicated on each other. I concluded that AMP model B is not attached to Channel B.
Re: Assign AMP A to channel A and AMP to channel B
by Krontab on 2012-09-08 06:50:53.5780
You are correct the AMP Channel B only gets used in bypass mode.
by fdesnoyers on 2012-09-08 13:11:30.9980
I just hope LINE6 will add the possibility to link amp model B ton channel B of a signle DT amplifier.
by DarthHollis on 2012-09-09 11:12:21.1160
I don't see any way that would be advantageous but maybe you could enlighten me.
For now you should make a product suggestion.
The way I see it, what you are suggesting would only take up DPS space on the POD HD.  It would be much easier to just have a different patch.  There's just no advantage that I can see.
by TheRealZap on 2012-09-09 12:49:30.7910
what you ask is impossible, because there is only a single set of circuitry inside the DT amp... it's mono...
so if you are trying to run amp a and amp b channel at the same time that's impossible.
you're clearly using a pod with it... making channel b worthless anyway...
because you can create a preset for channel a to be anything you want...
the amp becomes "dumb" once you use it with a pod... the pod is the brains.
by geppert on 2012-09-09 13:41:03.1440
Fdesnoyers,
The Real Zap is totally correct. As a stand alone amp, think of channels A & B on the DT as two presets alowing you to use one OR the other like the channel presets on the POD. It is a mono amp, one input only. I know it "looks" like two channels on the amp but it is really just two front end "presets" feeding either/or into a mono path. As TRZ explained, the POD takes over Channel A on the amp (if a POD amp or preamp model is active), if a POD amp model is not active then the DT switches automatically to Channel B but your POD's efx are all still alive. In otherwords (in the example without an active POD amp) you've got a "pedal board" with the DT's Channel B's onboard model(s) working depending on how you manually set it up. Hope this helps a bit to wrap your head around the concepts?
by fdesnoyers on 2012-09-09 13:41:11.5630
Maybe I was not clear enough and I apologize. I must admit title may lead to confusion
Assign AMP model A to channel A OR AMP model B to channel B
In this setup, I want to switch from clean tone to a heavy distortion just by hitting à FS to which I assigned many controls. Pressing FS8 change from clean sound (Enter Sandman Intro) to heavy distortion by changing amp model AND activating some effets. Amps models are not used together but in toggle mode, one at a time.
Default setup (HD500 initial state) = Amp model B: Hiwatt 100, clean mode (Voicing 1, Class A, Pentode) + effects. Amp model A is OFF.
Pressing FS8, turns amp model B OFF and amp model A ON.
Doing this, I see DT50 switching from channel B to channel A and all parameters defined for amp model A are applied to channel A (Class A/B, Pentode, Voicing IV)
But if I want amp model B sounds like I want, I must manually "prepare" channel B and set parameters as described. If I forget to set channel B prior to using this setup in HD500, I can end up with anything but what I originally planned. No big deal in practice mode but during live performance, not good
Since changing setup in HD500 requires more steps than for X3 LIVE, I found that it is easier to define 2 amps in the same setup and switch from amp model A to amp model B (and activate whatever effects you need for each sound) by pressing only a single switch.
Before using DT as my main amp, HD500 was connected to a mixing console and the setup was working as expected but without the warm sound of the DT amp.
Again, if it was possible to assign amp (in fact pre-amp as recommanded by LINE6) models to both channels (one at a time) of a single DT amp, I could reproduce the ease of switching amps in the same setup.
by fdesnoyers on 2012-09-09 13:45:31.6580
You are right and I think the way I wrote the title is not correct.
In fact, I want to use amp model A OR amp model B.
Please see answer I posted two minutes ago.
Thanks for the interest in my posting.
by geppert on 2012-09-09 14:10:24.3220
I think we were both writing our previous posts at the same time?
by fdesnoyers on 2012-09-11 15:33:27.4510
Yeh! It looks like that :)
by Lespaulidas on 2012-09-12 07:37:49.4570
I also wanted this to work when I first got my HD500 and DT50.
There is an advantage, maybe not for some but for others.  To each their own I guess.   When in "Pedal Board Mode", or whatever it's called, it would be nice to be able to do this.  Managing effects via tap dancing is natural for some guys like me, and I just wanted to be able to A/B amps,  clean to overdrive.  For example Bassman to Recto, and have all my effects stay on as I had them.    I like to play by feel on songs, along with turning effects on or off by feel based on that mood at the moment    So in that sense, to be able to switch amps on the fly without messing with the selected effects for that moment would be nice and that's why it's advantageous to some players..  Don't harp on it if you don't play that way...
See my thread here that was started over this same scenario.
http://line6.com/support/thread/56408?tstart=30">http://line6.com/support/thread/56408?tstart=30">http://line6.com/support/thread/56408?tstart=30
Now you can do this, but you have to have TWO DT amps. But, one would think with some simple programming tweaks, it could be done with one physical amp pretty easily if you can route it while two amps are connected in a LINK chain.
The other workaround is to have both virtual amps split in your HD500 chain, put a volume pedal right behind each virtual amp (two volume pedals -set to 0% vol.), and have a foot switch turn one off and one on at same time(volume pedals).  The down side is you have to kill two effect slots for the volume pedals to do this, which ruins the ldea of being in "Pedal Board Mode" and having all these effects at your disposal (well two less effects anyhow).
I hope they could enable this one day,  as it seems possible.
My two cents.
by fdesnoyers on 2012-09-12 10:20:50.0710
Regarding amps, emulating A/B box with volume pedals is not a bad idea if both amps use the same DT setup (Voicing, Pentode/triode, amp class), In my case, the 2 amps use very different setup.
  • Clean Sound
          Hiway 100 pre
          4X12 Hiway cab
          Class A
          Voicing I
          Pentode
  • Distorted sound
          Treadplate pre
          4X12 Tread V-30
          Class A/B
          Voicing III
          Pentode
So, switching from A to B with same DT50 setup on channel A doesn’t make the job
by radatats on 2013-01-27 21:07:39.9330
I don't see the need to switch to Channel B in the DT.  Try this.  Build your patch in the HD500 with two different amps, one clean and one distorted.  Assign one foot switch to turn amp A on AND amp B off and vice versa.  The switch will show as "Multi" now.  This way you essentially get your channel switching with the one foot switch.  You can also add effects to the same switch so that one foot switch either turns on the clean amp with effects off or turns the distorted amp on with effects on.
FS1  ON  = Clean amp ON / Distorted amp OFF / Effects OFF
FS1 OFF = Clean Amp OFF / Distorted amp ON / Effects ON
Keep playing with it, you will see what I mean.
