Main :: StageSource Speaker Community Support
2 L3t with 1 Subwoofer L3s?
by negatiefmann on 2012-09-17 02:04:12.7600
Hi there,
i`m a proud user of the Stagescape Mixer.
Now i`m thinking of buying new speakers also.
My request will be 2 L3t with 1 L3s (we are a small Rock Trio Band...it is only for the practiceroom and mini gigs).
Does it work? Does this make sense?
Re: 2 L3t with 1 Subwoofer L3s?
by line6jonb on 2012-09-20 09:17:42.5120
Hello,
2 L3t and 1 L3s will work great - especially with the StageScape mixer, because it is meant to be a system.  The feedback suppression on the mixer will work throughout your entire system, and with the L6 Link connection with AES/EBU cables (recommended up to 50' of length), a graphic equalizer can be placed on your main outs.   The L6 Link connection will also automatically configure your left and right speakers, and you will be able to control the crossover frequency to your sub from the board.  You can also ping your speakers, which makes the speaker LED light flash, in order to make sure your left is left and right is right.  Another possibility would be to use L3t's as monitors and still utilize the sub for extra low end.
I've used this system for a number of band rehearsals and have not had a problem.  Our drummer is pretty loud.  Plus, with 2 guitar half stacks, an 8 speaker bass cabinet and 2 microphones - I have yet to hear feedback.  The system is loud enough to keep up with the amps and drums, and can probably go louder than we would want to.
With that system I would be confident to walk into any bar/club/park and have a good show with very little worry or hastle about the setup or sound system.  The sub is of good size, but small enough to fit into the trunk of my Crown Victoria with the L3t's across the back seat with enough room for other passengers/gear.  Very ideal for practice spaces.
I hope this is helpful.
Jon
by groovedggr on 2012-09-20 21:22:10.4200
If I add L3t speakers to my M20d do I get more than 20 channels?
If not- than I don't see an advantage over the L3m as long as I'm using the M20d.
Please correct me if I'm wrong.
Thanks
