Main :: StageScape M20d Mixer Community Support
Phantom Power
by paulymusik on 2012-09-17 13:29:45.8870
Hallo,
today I wanted connect a new Condensor Micro, but I have no more Phantom power. If I choose the 48V button on the touch screen, it lights but I can not find any power on one of the twelve inputs.
Re: Phantom Power
by ArneLine6 on 2012-09-17 15:35:39.6390
When the 48V button is on  the phantom power is on for that row of inputs. Either 1-6 or 7-12.
Re: Phantom Power
by paulymusik on 2012-09-17 15:43:08.1550
Yes, I know.
Yesterday it was o.k., but today there is no power on each input. I checked it with an voltmeter
Re: Phantom Power
by dboomer on 2012-09-17 20:35:13.7130
Specifically, what microphone are you trying to power?
What pins did you measure across?
Re: Phantom Power
by paulymusik on 2012-09-18 13:16:06.7410
It was an AKG PG81 also an Sennehsier E 901
Measuring one pin across gnd
Re: Phantom Power
by dboomer on 2012-09-18 18:23:37.7140
Measuring that way will show zero volts.  You would have to measure from 2 or 3 to pin 1.  I must caution you against doing this without knowledge that your measurement won't draw too much current.
Have you tried using different mic cables.   Make certain that pin 1 is not connected to the shell as this may cause some mics not to work.
Re: Phantom Power
by paulymusik on 2012-09-19 15:11:57.5920
Ok, Ok, I used the pin 2 or 3 again 1
I tried six Mic cables. I´m in disussion with line 6 service. I hope it woll be soon repair,
