Main :: StageScape M20d Mixer Community Support
Can the USB to Computer feature be changed?
by blomasky on 2012-09-20 20:10:55.4020
I have to take the mixer output and stream it to the internet.  I can not use the USB to Computer connection since that is pre-fader, pre-mute, etc.)  I have to take the headphone output and bring that into the computer.  For those of us NOT recording via the USB, can the next firmware have an option to change the USB behavior to work like the main outputs?
thanks
bruce
Re: Can the USB to Computer feature be changed?
by ArneLine6 on 2012-09-20 20:39:45.1270
Hi Bruce,
The USB stream channels 19/20 from the M20d to the computer are streaming the main mix.
Cheers,
Arne
by blomasky on 2012-09-20 21:33:55.9360
what?  I am confused?  If I have mics / guitars plugged into 1-16 and have usb connected to my laptop, it seems like the audio that is input to the laptop is pre-Fx.    I dont understand your response Arnie.  Please clarify
Bruce
by ArneLine6 on 2012-09-20 21:47:37.2620
The USB stream from the M20d to the computer looks like this:
  • Channels 1-16: M20d Mic/Line Inputs 1-16, pre-processing / pre fader
  • Channels 17-18: M20d stereo Aux Input, pre-processing / pre-fader
  • Channels 19-20: M20d stereo Main Outs, post-processing / post-fader
If you select M20d USB channel 19/20 you have the main mix post processing, post fader. The same signal that goes to the main outputs.
Cheers
by blomasky on 2012-09-21 08:02:53.9250
When I plug this into my Mac Laptop and go to preferences / Sound I see M20D USB   I dont see any option to select any channels.  I want to use the M20 as my system input audio.  Do I need to do anything?
Bruce
by ArneLine6 on 2012-09-21 09:54:33.0680
In applications-> utilities-> audio midi setup you can select the stereo input. If you use a daw, all inputs show up there.
Cheers
by blomasky on 2012-09-21 10:08:01.4960
thanks Arne.. you da man!!
