Main :: StageScape M20d Mixer Community Support
Parametric EQ: Is it possible to extend the range of the PEQ MidQ parameter
by Ruben40 on 2012-09-21 03:14:46.2390
Hello
The MidQ q-factor parameter of the PEQ in the SS has a range from 0.1 to 10.
For some notch filter problems with the main speaker or monitor I would be good to extend PEQ MidQ range from 0.05 to 20 or 30.
That means the bandwith of the "notch" filter can be narrower and wider than now.
That means if you use it as a narrow notch filter you will get less changes in your pa or monitor sound.
Is it possible to make it awailable for the main and the monitor outputs in a future firmeware release ?
