Main :: POD HD
Can't post responses in forums too.
by DrFix on 2012-09-26 00:01:54.2560
I can't post responses on forum too! As well as other users are reporting...
I click on the reply button and nothing happens!
Re: Can't post responses in forums too.
by RICHJONES on 2012-09-26 12:42:12.2640
Just tried to start a new discussion twice and it erased my post both times and nothing else happened.
by toneman2121 on 2012-09-26 14:15:20.7020
yeah, some kind of glitch in the system
by Line6Tony on 2012-10-02 11:59:26.1140
Folks, please update me on the problems you've had with the forums. We think it's fixed but we need to know for sure. Thanks.
by rootsrocker on 2012-11-01 15:36:14.2280
I'm having this problem too.  I recently wrote a discussion, but when I click on the little 'reply' icon in the bottom right corner of any response it's not following through with the command.  Of course, it's only happening in the discussion I started - not in other's discussions such as this one I found whilst Googling for the solution.
by hurghanico on 2012-11-01 17:29:57.5420
I instead, often have problems when I try to edit/update my already existing posts, the only remedy I have found is to delete it and rewrite it completely..
by jimsreynolds on 2012-11-01 17:57:25.3920
Yes, I just had this issue too where I tried to fix my cruddy spelling and got a nasty error message of some kind.  Looks like the gremlins are back on the loose.
by hurghanico on 2012-11-01 19:19:53.0860
evidently the gremlins are here around from several days, because it's almost a week that I come across these errors
by fenders74 on 2012-11-02 03:28:53.0280
Nothing solved, can't start new 3d!!
by Octo777 on 2012-11-02 04:32:58.5690
I had a simialr problem in regards to starting a new thread the other day.
Brought up a support ticket and was told it was mostly likely intermittent server problems..........
by GTLazer on 2012-11-05 04:21:01.4620
I thought this was probably the best place for this under the circumstances.
I am unable to start a new discussion on the forum. When I click to post, it returns an error suggesting that my message is blank.
I've tried both Chrome and IE and they both do the same.
All help gratefully received.
Thanks.
by hurghanico on 2012-11-05 04:28:51.9810
I can no longer start a new dicussion and also I can no longer insert images (in any form) in my posts ..
opens a pop-up that says I am not authorized..
and also there's the still unresolved problem of being able to edit old posts
by jimsreynolds on 2012-11-05 05:29:34.1170
I tried to edit one of my 'Documents' earler and the content was rendered as raw HTML.   That is a little more clunky than I am willing to work with !!!  Imps are abounding.
by Line6Tony on 2012-11-05 10:18:07.4270
It looks like folks can create new posts now. Please reply here with any other system issues. I apologize for any inconveniences caused.
by jimsreynolds on 2012-11-06 09:56:55.7740
Thanks for coming in on this Tony.   I confirm that I can edit my document now as normal.
by hurghanico on 2012-11-06 10:11:41.2100
me also have no more problems with my posts..
Thanks
by hurghanico on 2012-11-06 13:11:12.0960
there are once again problems to edit posts
by davidb7170 on 2012-11-06 15:32:02.3570
I could reply to, but not edit my reply.... I always copy my typing before hitting post, as I've been stung before...
Dave
by hurghanico on 2012-11-06 16:26:51.6710
good strategy...
I do the same thing too
