Main :: Vyzex Editor
Pocket Pod Restarts
by RevLancE on 2012-09-28 04:58:19
...When I plug in My Pocket POD to My PC, then launch Vyzex, My Pocket POD Restarts...usually instantly, as well as whenever I attempt to save any Tones, rendering them unable to Save and useless. Any ideas?
Thanks,
LancE
Re: Pocket Pod Restarts
by PsychoPops on 2013-01-05 09:44:50
I just got my pocket pod and in setting it up and reading the instructions this is one of the fist things I read that might help you out.
The following USB ports are known to cause Pocket POD to spontaneously reset its drivers and
reboot itself when accessed by connected MIDI software:
 All USB hubs including many USB ports built into laptop PCs,
 Mac Tower: The front USB port
 Macbook: The back (left) USB port
 Macbook Pro: The right USB ports
PLEASE ENSURE YOUR POCKET POD IS CONNECTED THROUGH A RELIABLE USB PORT BEFORE PROCEEDING!
Everything checked on the list above? Great! Now you should quit any MIDI port using music software you
have running before you launch the program for the first time – This will avoid any possible conflicts between
Vyzex and your other MIDI software on the program’s maiden voyage.
Hope this helps you. Can't believe no one has responded to you in 3 months.;o(
