Main :: POD HD
HD series much better than the POD Studio UX1??
by otiss on 2012-10-07 07:05:36.3680
Hello,
I have a question reagrding the HD series. I currently own the POD Studio UX1 which I use for home recording, and I was wondering if purchasing one of the HD POD's would make a major difference.
The UX1 has given me no issues so far, but if the HD would give me significantly better recordings and possibilities compared to the UX1, I would consider buying it.
So are there any people that have had experience with both and know if it is really much better? My main concern is the price of the HD (it's quite expensive) and I want to know if it is worth the investment.
Thanks in advance,
Otis
Re: HD series much better than the POD Studio UX1??
by TheRealZap on 2012-10-07 08:31:43.7720
If you're primary interest is recording, I would hold off on the HD's The sound quality is better on the HD's but it will affect your workflow, since it doesn't do simultaneous wet/dry out or have a VST plugin that you can use... assuming you use those features....
who knows? those features may come to the HD over time...
by DeanDinosaur on 2012-10-07 14:45:00.5530
The amp modeling in the HD is newer generation. There's so much more improvement in the feel department, the sound is much richer, it feels and sound closer to real amps than POD Farm. The disadvantage is not having the routing flexibilty but still for recording I would chose the POD HD over previous PODs/UX/Pod Farm anytime. For guitar sound, I no longer have any use for POD Farm/X3 Xt modeling even if someone gives them away for free, I would use POD HD instead.
In summary it's a Major improvement to Amp modeling.
by TheRealZap on 2012-10-07 15:13:51.9850
all true. sound quality is no contest.
by CairnsFella on 2012-10-07 19:00:40.8760
I thought the 300 Or 400 may do wet / dry out in so much that you could record dry whilst monitoring wet?
by TheRealZap on 2012-10-07 19:24:17.3320
not over USB none of them will.
by CairnsFella on 2012-10-07 19:29:58.7060
No not over usb (I thought I had kind of said that by saying 'record' dry, and 'monitor' wet.)
I realise this may not be the full extent of flexibility that the OP wants, but its is at least a 'true' option, as opposed to the rather fudged workaround that exists for the 500.
by TheRealZap on 2012-10-08 06:00:06.0040
You may be right there, I seem to remember a feature like that, I just never use it... sounds worth looking into though if it would suit your needs.
but then you'd end up processing it with pod farm or similar VST software and lose the HD quality...
by CairnsFella on 2012-10-09 20:48:25.6940
Very good point, and one I hadnt considered.
That said, you'd at least HAVE the option of recording wet with the HD quality, or re-effectong / amping with other software.
Having said all this, another Expert on another tread has adamantly advised that the wet/dry monitoring / recording set up I speak of doesnt exist. I am yet to locate where I read about it, though I know I read of it more than once, as it was a factor I considered when ultimately purchasing my 500. However, as I do not have the other models - and in light of wehat I havew recently been told - it seems what I suggested is not an option.
