Main :: XD-V Digital Wireless Microphones
wireless mic forums
Replacement windscreen for HS70 headset
by motnik on 2012-10-07 21:03:34.6280
Short and sweet: where can I find replacement windscreens for HS70 headsets, both black and tan?
Thank you very much!
Re: Replacement windscreen for HS70 headset
by RonMarton on 2012-10-08 08:03:31.2930
http://www.amazon.com/Tetra-Teknica-XFFZDP-BLK-Headset-Microphone-Windscreen/dp/B006HNRXV8/ref=sr_1_fkmr0_2?s=musical-instruments&ie=UTF8&qid=1349707816&sr=1-2-fkmr0&keywords=Tetra-Teknica+XFFZDP-BGE
http://www.amazon.com/Tetra-Teknica-XFFZDP-BGE-Headset-Microphone-Windscreen/dp/B006HJ58EG/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1349707816&sr=1-1&keywords=Tetra-Teknica+XFFZDP-BGE
These are the closest that I've been able to find.
The foam "pompom" may have a larger outside diameter than you expect, but they should work OK.
I find that tiny drops of clear silicon "goo" sealant (carefully applied to the side barrel of the mic head from the head of a pin) work really well to prevent foam windscreens falling off.
The silicon goo is relatively easy to scrape off for subsequent re-application when replacement's eventually needed.
by motnik on 2012-10-08 11:37:04.3710
Hi Ron, thanks a lot for the suggestions! I will give them a try, however the reviews state they are a little bulky. What do think about using windscreens for Countryman E6 for the HS70? The mic capsules seems to be fairly comparable in size?
http://www.sweetwater.com/c377--Windscreens/popular/params=eyJkaW1lbnNpb24iOnsiQnJhbmQiOlsiNDI5NDk2Njk5MyJdfX0">http://www.sweetwater.com/c377--Windscreens/popular/params=eyJkaW1lbnNpb24iOnsiQnJhbmQiOlsiNDI5NDk2Njk5MyJdfX0">http://www.sweetwater.com/c377--Windscreens/popular/params=eyJkaW1lbnNpb24iOnsiQnJhbmQiOlsiNDI5NDk2Njk5MyJdfX0
P.S.: I wish Line 6 would offer replacement windsceens in their web shop.
by RonMarton on 2012-10-08 15:12:35.8540
Re your heartfelt P.S.
...So do I, ...man, so do I !
Those Countryman foamies will be perfect, fitting far better than Amazon's Tetra-Teknica "dozen for the price of one", but (like nearly all of the "brand name" ones out there) it is a heck of a lot to pay for a few square millimetres of expanded polyurethane.
Generally speaking, however, my preference is for the better blast filtering and road-shock protection afforded by oversize windgags, even if I do have to resort to my "Silastic Goo" technique to keep them on.
Just remember to keep any such "goo" to a minimum, ...well clear of the microphones' acoustic inlet openings.
