UX1 - no sound
by leogauvain on 2012-10-12 09:27:27.7420
Just got a UX1. Set up output through headphones. Using Win7. Pod Farm recognises input. No sound output. HELP...pls
Re: UX1 - no sound
by TheRealZap on 2012-10-12 09:57:06.6360
are your headphones plugged into the UX1? (won't work with headphones plugged into computer)
Re: UX1 - no sound
by leogauvain on 2012-10-12 10:27:31.8090
Plugged into UX1
Re: UX1 - no sound
by TheRealZap on 2012-10-12 10:31:06.9170
make sure that the UX1 is set as the default playback card in your sound properties
Re: UX1 - no sound
by leogauvain on 2012-10-12 11:03:33.7670
already is
Re: UX1 - no sound
by Triryche on 2012-10-12 11:26:18.5100
How are you launching POD Farm?
Re: UX1 - no sound
by leogauvain on 2012-10-12 11:28:12.9860
dont really undestand the question.......off a shortcut on my desktop?
Re: UX1 - no sound
by Triryche on 2012-10-12 11:39:27.3520
OK, just making sure you weren't launching the plug-in within a DAW.
In your Mixer view check to make sure you are selecting the correct option (Instrument/Mic).
Also, do you see the meters moving in the POD Farm mixer view?
Re: UX1 - no sound
by leogauvain on 2012-10-12 11:42:45.8490
I am not using daw. Is on instrument, input moving but output isnt
Re: UX1 - no sound
by Triryche on 2012-10-12 11:47:11.2390
Did you check to make sure something in your signal chain in POD Farm is not muting the signal?
Re: UX1 - no sound
by leogauvain on 2012-10-12 11:52:48.9230
nothing that i can see
Re: UX1 - no sound
by Triryche on 2012-10-12 12:13:14.0690
If you run Monkey 1.59, you have green ticks for everything?
Re: UX1 - no sound
by leogauvain on 2012-10-12 12:26:46.9890
gear box is not installed, i guess i dont need it?
Re: UX1 - no sound
by Triryche on 2012-10-12 12:40:14.4970
Correct, you do not need gear box.
Also make sure you have all your windows updates, especialy concerning C++.
Do you have powered speakers or an amp you can check the UX's analog outs with? (Doubt that is an issue if you are not seeing any output in PF).
Can you try it on another computer?
Re: UX1 - no sound
by leogauvain on 2012-10-12 12:59:45.5270
Currently updating windows software, tried with an amp, fine when i play music off it but not working through pod farm. Sounds more like a software problem? Is it possible that My prefences are set up wrong? also, I dont have access to another computer
Re: UX1 - no sound
by Triryche on 2012-10-12 14:05:34.3850
Did you run the license manager to authorize the UX?
Re: UX1 - no sound
by leogauvain on 2012-10-12 14:29:22.3280
worked after windows update thanks!!
