Main :: M5 / M9 / M13
output signals
by finchmark on 2012-10-19 05:12:59.1360
Hi, I want to split my signal at the output stage of an m13 with equal quality/signal coming from both outputs but i dont know if the same signal comes out of each output. P
lease can somebody let me know how the outputs work bearing the above in mind. Many thanks
Re: output signals
by phil_m on 2012-10-19 06:17:47.6440
If you want to split the signal to go to two amps or something like that, simply using the left and right outputs will probably be the best way to go. Some of the effects are stereo, so the signals won't necessarily be exactly the same, but they would sound great with a dual amp setup. If you actually do want to send the exact same signal to both amps (or whatever it you're sending the signal to) the correct way to do that would be to get an A/B/Y box or other active splitter box and take the output from the left output and split it into two mono signals.
Re: output signals
by finchmark on 2012-10-19 06:36:02.5690
Hi, many thanks for that, would that not weaken the signal by halving it or something? (Might b a silly question?) Thanks
Re: output signals
by phil_m on 2012-10-19 06:52:16.2130
Are you talking about using the two outputs on the M13 or using a splitter? Using the M13's dual outputs won't weaken the signal. The only instance in which I could some signal weakening is when you were bypassing the M13's effects while true bypass mode, but even then I don't know if it would be an issue. But otherwise, there's no difference in signal strength between using one of the M13's outputs compared to two.
Re: output signals
by finchmark on 2012-10-19 07:36:38.8670
I want to split the signal into two amps then on one of then place a volume pedal before some fx I can then fade in at will, also I don't use any stereo Fox so should be ok?
Re: output signals
by phil_m on 2012-10-19 07:42:16.5680
Yeah, I don't see any reason that wouldn't work. I've hooked my M13 to two amps many times.
Re: output signals
by finchmark on 2012-10-19 07:59:47.5130
Many thanks for your help
